MUM Europe 2020
Equis
Forum Veteran
Forum Veteran
ospf config help
Mon Oct 09, 2006 1:16 am
Hello
I have 2 routers & mail server A--B--C
B is my mail server, C is to the internet, A is backup internet.
I use ospf but mailserver always chooses A for defualt gateway when I want C
I tryied changing Prority, Cost but to no luck.
Is 1 high prority and 255 low or the other way around?
Can anyone give me config tips?
tneumann
Mon Oct 09, 2006 1:27 am
What OSPF software are you running on the mail server?
Regarding priority, this parameter is not meant to influence the preferrability of routes but the chance/egilibility of OSPF routers to become DR/BDR (designated routers) of an area.
What you're looking for is the cost parameter, and that can be set per interface, where higher cost means less-preferable for a route that points to that interface.
--Tom
Equis
Forum Veteran
Forum Veteran
Tue Oct 10, 2006 12:33 pm
I am using Quagga.
I must be doing something wrong.
On one server (test) it picked the correct gateway then I tested fallover, it worked perfect, but now wont fall back to the original
Users browsing this forum: Google [Bot], jondavy, screenie, slv and 124 guests
