MUM Europe 2020
zsnle
Mikrotik licensing
Wed Oct 12, 2016 6:36 pm
I have RouterBOARD that needs upgrade. Version is 5.25, current available version is 6.37.
Documentation:
The RouterBOARD comes with an embedded license. You cannot move this license to a new system in any way, this includes upgrades applied to the RouterBOARD while it was still working.
Am I allowed to upgrade to 6.37?
What happens if there is a problem, ie. router does not boot after upgrade and I need to use serial/netinstall/...?
I have already exported currently valid (embedded) key.
ZeroByte
Re: Mikrotik licensing
Wed Oct 12, 2016 6:50 pm
I know that the system ID format changed some time ago, but I can't remember if it was 4->5 or 5->6.
(actually I just checked and this was 3 -> 4)
You shouldn't have any license issues upgrading from 5 to 6. The main thing is do not format the NAND from the console boot menu - I did that once and had to get an entirely new license generated by support. Netinstall can retreive the license key from the unit for you and you can copy/paste that into a text file for safe keeping.
One thing to be careful about in your upgrade is that the simple queues made some big changes from version 5 to 6, so if your configuration uses them, you need to back up your router and have a copy of the firmware for your current version available in case your configuration doesn't translate well in the upgrade process and you need to downgrade.
When given a spoon,
you should not cling to your fork.
The soup will get cold.
Splash
Wed Oct 12, 2016 6:51 pm
If you look under System --> License it will show you what the latest support version you are allowed to run with your current license if I remember correctly.
Basically, you can upgrade your device without any problems, and the RouterOS should automatically convert your config from v5 to v6 (sometimes its not always 100% depending on what you have running, but 99% of the times its fine).
You wont need to apply any licenses etc.
MTCNA, MTCRE, MTCINE, MTCTCE, MTCIPv6E, MTCUME
jarda
Mon Oct 17, 2016 8:34 am
Update without problems? Definitely not if he has a mipsle cpu...
Users browsing this forum: Mimi53, sopyan0807 and 163 guests
