Vitor
What is the maximum number of users authenticated in RB941 and RB952
Sat Oct 29, 2016 12:15 am
Hi everyone,
Does anyone know how many simultaneous users can be authenticated in the in the following RBs?
RB952Ui-5ac2nD
RB941-2nD
RB1100AHx2
I was looking and didn't find out. Is there any link or site with this information.
Thanks in advanced for your help
Best Regards
cutedrummerboy
Re: What is the maximum number of users authenticated in RB941 and RB952
Sat Oct 29, 2016 9:31 pm
Device: RB2011UIAS-RM, RB750GL, CISCO SG300-28, UNIFI UAP-LR
Vitor
Sun Oct 30, 2016 10:16 pm
Thanks for the link. It has some useful information.
TomjNorthIdaho
Tue Nov 01, 2016 3:08 pm
Authenticated users or active users ? There is a big difference.
If you are asking about active users over wireless - then many other things are needed to also be known...
- wireless protocol (are you taking measures to avoid B protect mode)
- band 2.4 ghz or 5 ghz
- average signal strength and weakest signal strengths (also CCQs)
- distance
- how many connected
- how many uploading and downloading
- what are your QOS up/down speed limits (if any)
- What are your slowest guaranteed up/down rates (CIR)
Depending on you answers to the following for wireless connections - the answer you seek could be as small as ( 1 ) or as large as ( 100 ) give or take
North Idaho Tom Jones
whittle
Thu Jan 26, 2017 6:55 pm
I have RB952Ui-5ac2nD and i made a hotspot(captive portal), what is the maximum number of users active on the hotspot?
I know that license 4 gives 200 HotSpot active users but can 200 users use the internet at the same time on this router?
TomjNorthIdaho
Thu Jan 26, 2017 7:21 pm
A HotSpot with 200 wireless active will work - but not fast for everybody at the same time.
It should work just OK with 200 connections but with about 10 to 20 percent of those connections running (a meg or 2 meg per user at most with 10 to 20 active users).
If you need to support 200 active connections and want the best possible throughput for everybody at the same time, then I would suggest one of the following two below:
- #1 Four APs with 90 degree sector antennas which will then cover a 360 degree pattern. Then use 2.4 GHz channels 1,4,8,11
- #2 Possibly repeat the #1 with each repeated set of APs spread out where they are at least 100 to 200 feet apart - then turn down the power on the APs.
Also, You might want to throw up some 5 GHz HotSpot APs so that you have a mix of 2.4 GHz and 5 GHz APs.
Pretty much no matter what you do, it is very difficult to have 200 active users all downloading at 5 meg each or even 1 meg each all at the same time.
Users browsing this forum: Baidu [Spider], biomesh, Zacharias and 78 guests
