mykhairi
RB750UP port problem
Tue Nov 01, 2016 3:51 am
Good day to all
Just to query about issue like below.
My RB750UP port 2 and port 3 poe out ok, but no data...Just want know what happen to this port.....port 2 and port 3
As per screenshot below...what is the issue with the port....if can solve, how the process to solve it...
Thanks in advance...
Khairi...beginner Mikrotik
Rudios
Forum Veteran
Forum Veteran
Re: RB750UP port problem
Tue Nov 01, 2016 9:58 am
The description is quite obvious (is there a loop)
Without you telling us what is connected to the ports it is very difficult to tell what is going on.
Testing setup with: 2 x RB750UP | 2 x RB750GL | 1 x RB951G-2HnD | 1 x RB2011UiAS-IN
mykhairi
Wed Nov 02, 2016 2:54 am
thanks for the reply...
For info....no physical connection connected/plug in to both port... port 2 and port 3...
As shown both port shown signage RS and link ok but no physical connection connected...
Even if I plugin direct from computer/device to that port, no data/can't do anything i.e winbox of webfig...poe port function efficiently, can power up mikrotik device...
Thanks again for any comment
Rudios
Forum Veteran
Forum Veteran
Fri Nov 04, 2016 12:51 pm
I would try to re-install RouterOS and if that doesn't help I would contact MikroTik support or your supplier because I assume it could be a hardware fault.
mykhairi
Wed Nov 09, 2016 5:36 am
already refer with distributor/reseller, nothing can do since distributor suspect over voltage incoming power/current to the routerboard...ask me to buy a new one since already expired warranty.....huhuhuhu
Any feedback/comment/experience issue like this....thanks in advance
Users browsing this forum: No registered users and 165 guests
