jo2jo
Forum Veteran
Forum Veteran
powering RB off 4 molex computer line?
Mon Oct 16, 2006 9:50 pm
Since ive read the RB can run at 12vDC and i know it usually consumes under 1A, how could u rig it up to feed from a hard drive type 4 pin molex connector where you hae 5v and 12v sources?
tks
GotNet
Tue Oct 17, 2006 2:55 am
Just use the black and yellow for 12 volts -IF- the power supply is already powering a motherboard. If not then don't use that supply. Not worth the time and power draw to properly load the 5 volt side.
Mike
Gerard
Trainer
Trainer
Tue Oct 17, 2006 5:12 am
Just use the black and red for 12 volts
Correct me if I'm wrong, But I believe the Black and Yellow are for 12 volts.
-Gerard
Quick google found this..
GotNet
Tue Oct 17, 2006 6:00 am
Thanks for the correction, Gerard. That is correct!
Mike
jo2jo
Forum Veteran
Forum Veteran
Tue Oct 17, 2006 7:43 am
so just cut a normal power cord and solder one to yellow and one black?
thanks!
janisk
Tue Oct 17, 2006 12:51 pm
just a thought - PC PSU is thought to work on all lines +3.3v +5V +12V and use them all, if u use only one line you will eeventualy damage your PSU :roll:
jo2jo
Forum Veteran
Forum Veteran
Tue Oct 17, 2006 5:26 pm
janisk,
I dont know about that...i have many fans and lighting and water cooling accessories on my hobbie machines that's molex connectors only feed of one line and i have psus going on 3 years with no issues...i still dont see where to attach the 12v line on the MT board though..
tks
jo2jo
Forum Veteran
Forum Veteran
Thu Oct 19, 2006 11:25 pm
anyone know where to attach the 12v line on the MT board though? Its the same location as where you attach the positive and neg. when using a 12v battery.
Im actually trying to do this inside of an xbox, off it's molex HDD power cable.
tks
Stryker777
Fri Oct 20, 2006 1:11 am
I do not have a MT connected to a pc psu but i do have pc PSU set up for power to other equipment and power banks.
I use just the 12v side quite often. I have the 5v side open for use and leds to show the voltage status of each line. The only thing I had to do to make them work without a pc was load the logic line off 5vdc so it would power on when the main switch was turned on and I put a resistor on the 12v side to make sure there was always a load on it because pc psus are stepping transformers.
Good luck
jo2jo
Forum Veteran
Forum Veteran
Fri Oct 20, 2006 1:15 am
stryker, thanks for your reply, I may be asking a very dumb question, but i need to know where on the MT do i connect the REd and Black of the PSU or any 12v source for that matter.
thanks
Stryker777
Fri Oct 20, 2006 5:48 am
I would have to look but it should be center pin is + and the yellow wire is +.
Normally center is positive. I would check it though by using a multimeter on the current power connector. Dont solder it into the mikrotik though, just put a connector on the wires so you can plug it in. Then it can be used on a poe injector bank or on a box it self.
Users browsing this forum: bangelov, Renfrew, W4WN and 102 guests
