ptr727
DNS Rebinding and Plex
Sat Dec 03, 2016 5:40 pm
Hi, I am having problems accessing my Plex server from my local network.
The problem seems to be related to "DNS Rebinding Protection"
I've searched this forum, and people report that it just works, but there are several references to other DNS servers or routers where DNS rebinding configuration is required.
See:
https://support.plex.tv/hc/en-us/articl ... onnections
https://forums.plex.tv/discussion/20117 ... ter#latest
Example error:
Example nslookup, Google DNS works, Mikrotik DNS fails:
> server 8.8.8.8
Default Server:  google-public-dns-a.google.com
Address:  8.8.8.8
> 192-168-1-47.d3628f4938a748af9a3e90f5ef365efa.plex.direct
Address:  8.8.8.8
Non-authoritative answer:
Address:  192.168.1.47
> server 192.168.1.1
Default Server:  [192.168.1.1]
Address:  192.168.1.1
*** No internal type for both IPv4 and IPv6 Addresses (A+AAAA) records available for 192-168-1-47.d3628f4938a748af9a3e90f5ef365efa.plex.direct
Ho do I allow DNS rebinding on the Mikrotik DNS server?
msatter
Re: DNS Rebinding and Plex
Sat Dec 03, 2016 5:49 pm
Try to put the address: 192-168-1-47.d3628f4938a748af9a3e90f5ef365efa.plex.direct in the static DNS list of the Mikrotik with IP 192.168.1.47
One RB4011 (cooled) and a RB760iGS (hEX S) in series. 4011 Does PPPoE/IKEv2.
Running:
RouterOS 6.47 / Winbox 3.24 / MikroTik APP 1.3.12
NordVPN viewtopic.php?f=2&t=158439&p=781009 for multiple connections.
ptr727
Sat Dec 03, 2016 5:54 pm
The address is dynamic, the GUID looking part of the name is a dynamically generated security token, so adding a static entry will not work, or will work for a short time, until the token is regenerated.
In dnsmasq the equivalent option is "rebind-domain-ok=/plex.direct/"
In pfSense the equivalent option is "private-domain: "plex.direct""
I'm looking for an equivalent configuration option?
2frogs
Long time Member
Long time Member
Sat Dec 03, 2016 9:05 pm
Do you have port 32400 forwarded to your Plex server? Or have upnp setup?
ptr727
Sat Dec 03, 2016 9:25 pm
This is for local LAN access, not external access.
Sob
Sat Dec 03, 2016 9:53 pm
I don't think it's the router, I've never encountered any kind of such filtering in RouterOS. It's most likely filtered by parent resolvers, i.e. those set in IP->DNS.
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply. Not intended as incentive for masochists.
msatter
Sat Dec 03, 2016 9:55 pm
OK my answer stays the same but then you have to use the regexp field
*\\.plex\\.direct
I can't test it for you because I don't use this, but DNSmasq.
Running:
ptr727
Sat Dec 03, 2016 9:57 pm
That's it, thank you.
I tested local vs. Google, but I am using OpenDNS as DNS.
> server 208.67.222.222
Default Server:  resolver1.opendns.com
Address:  208.67.222.222
> server 8.8.8.8
Address:  8.8.8.8
Address:  8.8.8.8
Sob
Sat Dec 03, 2016 10:17 pm
If you want to keep OpenDNS, you can do this:
/ip firewall layer7-protocol
add name=plex.direct regexp="\\x04plex\\x06direct.\\x01\$"
add action=dst-nat chain=dstnat dst-address-type=local dst-port=53 in-interface=<LAN> \
    layer7-protocol=plex.direct protocol=udp to-addresses=8.8.8.8
It's far from perfect, but as long as your devices will use only udp dns (most do), it will work.
ptr727
Sun Dec 04, 2016 4:16 am
I found a setting in OpenDNS that turns of "Suspicious Responses" / "Block internal IP addresses", and that solved the problem.
Unfortunately there is no support in OpenDNS (at least in my home plan) that allows per domain exclusions.
Thank you all for the help.
msatter
Sun Dec 04, 2016 1:39 pm
You could filter that out in your Mikrotik and you have two solutions mentioned above.
Running:
jonmansey
Wed May 20, 2020 10:36 pm
In case it helps anyone else, I found I had to use the following regex to make the static dns entry work. (I had to add the leading .)
.*.plex.direct
Users browsing this forum: markos222 and 81 guests
