toxicfusion
input drop all rule - moved by accident!!
Wed Dec 07, 2016 6:13 pm
Hey there,
I was in a customer router (Winbox) monitoring traffic and doing a review of the firewall rules....
SOMEHOW, when I was ready to close the firewall window -- the filter input = drop all rule, got moved to top of list.
I realized this and tried to move it back below the filter accept rules, was too late and lost connection.
Their outside port forwarding / dst-nat rules appear to still be working.
How can I be able to correct this?
onsite visit and connect to router and Use neighbor discovery? Or completely locked out from accessing and require a full reset?
tslytsly
Re: input drop all rule - moved by accident!!
Wed Dec 07, 2016 6:23 pm
Hi Toxicfusion,
I'm afraid that you will likely have to go to site and connect via console cable.
This is why the Safe Mode is so good....
There are 10 types of people in this world:
  • Those who understand binary
    Those who don't
    and those that didn't expect me to be using Ternary!
:lol:
freemannnn
Long time Member
Long time Member
Wed Dec 07, 2016 6:24 pm
next time use "safe mode". better safe than sorry.
"lol i dont use safe mode also"
tell us what u finally did
toxicfusion
Absolutely love safe mode. However, unfortunately by default winbox does not connect via safe mode
When i make any config changes, I'll enable safe mode prior to changes. However, it was one of those -- let me watch some VOIP traffic and look over my firewall rules. As last night I made some rule changes and more traffic shaping, so was watching on business hours traffic.
toxicfusion
Wed Dec 07, 2016 6:26 pm
access via console... its a RB2011 device
There is a Mini USB port in front, can connect with mini-usb and use terminal?
Idea's?
tslytsly
Wed Dec 07, 2016 6:31 pm
Idea's?
RB2011's have an RJ45 Cisco type serial connection.
    Those who don't
:lol:
freemannnn
Long time Member
Long time Member
Wed Dec 07, 2016 6:32 pm
there should be an option in winbox start screen like "connect in safe mode"
nickshore
there is an rj45 on the back or just use winbox to a mac address if you are plugged into one of the ethernets
Nick Shore MTCNA MTCWE MTCRE MTCINE MTCTCE
LinITX.com - MultiThread Consultants
Get your MikroTik RBs and Training: http://linitx.com/brand/mikrotik
Official UK MikroTik Distributor
IRC chan: #routerboard on irc.z.je (IPv4 and IPv6)
nescafe2002
Long time Member
Long time Member
Wed Dec 07, 2016 6:34 pm
Just connect via MAC and you can bypass the (IP) firewall.
Assuming you haven't disabled WinBox interface under MAC Server :)
tslytsly
Just had to say that I'm proud to have ninja'd 2 posts! :lol:
    Those who don't
:lol:
toxicfusion
Wed Dec 07, 2016 6:39 pm
Thanks guys!
I'm aware of the Winbox MAC connect (Neighbor) This was my first guess to access the device, but was uncertain if it would 100% bypass the firewall filter rules.
I have a cisco style rj45 console cable. Will go onsite and make it happen.
FYI: I'm using Winbox version 3.7 -- there is no option to connect with safemode
also newer versions of winbox do not have the 'Connect To:' drop list for finding MicroTik's via Mac addr, so have to use Neighbor.
freemannnn
Long time Member
Long time Member
Wed Dec 07, 2016 6:42 pm
safe mode is avalaible after you connect to a site. top left.
my #7 post was a suggestion to mikrotik to place an option before you connect to a site
toxicfusion
Wed Dec 07, 2016 6:43 pm
Correct - which I use when I make config changes. Just waiting for feature request to be added to winbox for 'connect with safemode'
Will let you guys know if i'm able to regain access
toxicfusion
Wed Dec 07, 2016 7:00 pm
You guys were on fire today replying to post ;). Appreciated!
toxicfusion
Wed Dec 07, 2016 7:23 pm
update:
I just tested this scenario with a spare mikrotik i have in the office. Winbox worked perfectly using mac address, didnt even need to configure an IP on the laptop NIC interface.
However, I tried a tripp-lite USB to Rj45 console cable -- this doesnt appear to work for console? Nothing displays, baud 9600
tslytsly
Wed Dec 07, 2016 8:44 pm
update:
default baud is 115200 on Mikrotik
    Those who don't
:lol:
estar
Wed Dec 07, 2016 9:39 pm
I've got out of sticky situations before by using the MAC telnet if your connected via layer 3. If not working fromm winbox try using a teminal from a neighbour router that you can access on the same layer3 network.
Often you can access because it bypasses the IP side of the firewall just using mac address
E-star.uk - presents:
Star-charge - Cloud based user self-service billing system - including self-service secure WPA2 hotspot - Signup and try instantly - Made for Mikrotik OS.
https://e-star.uk/hotspot-routers.html
Sob
Wed Dec 07, 2016 9:45 pm
Simply connect over IPv6. ;) Ok, I know I'm not being helpful, because if you had it, you'd know to use it. So just for future reference, maybe it will inspire someone. It's really great thing to have, if for nothing else, then for situations like this. No matter how much you mess up one protocol's firewall, it does not affect the other one.
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply.
toxicfusion
Thu Dec 08, 2016 6:21 pm
Thanks everyone!
Noted about the baud rate needing to be 115200...
Customer is all set, connected using MAC address method within Winbox
NOTE: we do provide them fiber to their office, however I have telnet service disabled on the customer MikroTiks
I'll keep this in mind for future though!!
Users browsing this forum: No registered users and 112 guests
