Hydro
DHCP problem with 2.9.33
Thu Oct 19, 2006 4:20 pm
After upgrade DHCP servers on wireless devices show as invalid and will not assign an address.
Hydro
sergejs
Thu Oct 19, 2006 4:31 pm
Send support output file to the support (support@Mikrotik.com).
Make sure that you have configured DHCP-server for bridge (if you are using bridge), check that '/ip address' contains correct address for the interface DHCP is enabled on.
Hydro
Thu Oct 19, 2006 4:52 pm
I sent 2 of them to you and the one named support2 has now been downgraded back to .32 and is working fine.
Hydro
kolorasta
Thu Oct 19, 2006 4:53 pm
i think i have the same problem...
in the log says: dhcp1: failed to add arp entry for IP xxx.xxx.xxx.xxx: no interface provided (6)
and in dhcp server, dhcp1 appears with an "I" (invalid)
kolorasta
Thu Oct 19, 2006 5:01 pm
i disabled and then enable the dhcp server and the I (invalid) flag dissapeared and is working fine, until i reboot... dhcp appears as Invalid again until i disable / enable server
cmit
Thu Oct 19, 2006 5:03 pm
I had a (perhaps related?) problem yesterday:
When trying to configure a DHCP server on a virtual-ap interface (ROS 2.9.32), it always was shown as "invalid" (and didn't work), although the config was correct.
I didn't take the time to take a sup-out, though...
Best regards,
Christian Meis
tneumann
Thu Oct 19, 2006 10:11 pm
I have the same problem with 2.9.33. It was OK with 2.9.32
--Tom
Hellbound
Long time Member
Long time Member
Re: DHCP problem with 2.9.33
Thu Oct 19, 2006 10:35 pm
Hydro
I do suggest not to update anymore until they patched another 50 version... maybe then later give it a try... I stopped doing that since 2.9.28... lots of weird things going on since then
Hydro
Fri Oct 20, 2006 5:14 am
I tried the disable and re-enable, no luck here.
Hydro
normis
Fri Oct 20, 2006 10:02 am
Bug was introduced in RouterOS version 2.9.33 and will be fixed in
2.9.34.
Workaround (has to be done once after every reboot):
1) disable all hotspot servers;
2) disable all dhcp servers;
3) disable all dhcp relays;
4) wait at least 12s (optional - may work without waiting as well);
5) enable back dhcp servers;
6) enable back dhcp relays;
7) enable back hotspot servers;
balimore
Forum Veteran
Forum Veteran
Fri Oct 20, 2006 2:37 pm
2.9.34.
thanks, for your answered...this morning i downloaded ...33. and will cancel to updates...if not, maybe all client is.....
regards
Hasbullah.com
phil@nowires.com.au
Fri Oct 20, 2006 3:47 pm
Just installed version 2.9.34... it fixed the problem.
Regards...ƒil
kolorasta
Mon Oct 23, 2006 6:37 pm
i upgraded to 2.9.34 and after reboot i get this console error:
Uncompressing Linux...
ran out of input data
----System halted
how can i fix it?
cmit
Mon Oct 23, 2006 7:25 pm
I think you should re-install RouterOS...
Best regards,
Christian Meis
Best regards,
Christian Meis
kolorasta
Mon Oct 23, 2006 9:18 pm
Best regards,
Christian Meis
but why this happens?
cmit
Mon Oct 23, 2006 10:58 pm
I have no idea - what system is this?
A RB532? Some x86 system?
Sounds like the system package got corrupted or something like that (initrd seems to be damaged).
Best regards,
Christian Meis
Best regards,
Christian Meis
kolorasta
Tue Oct 24, 2006 12:20 am
Best regards,
Christian Meis
it´s an x86 system
hd is has errors...
bside
Thu Nov 09, 2006 11:17 pm
Same problem with DHCP after upgrading Wi-Fi card. Damn! Solutions from here don't work. Any workaround?
sergejs
Fri Nov 10, 2006 8:48 am
Bside, have you upgraded router to 2.9.35 version or you changed wireless card ?
provide us with more detailed information.
Users browsing this forum: antant, Bing [Bot], Majestic-12 [Bot] and 79 guests
