vishakhdeep
i want to spread copper wire in my area, not fiber with switch at every 100 mtrs., will it work ??? or might v any probl
Fri Dec 16, 2016 9:23 pm
i want to spread copper wire in my area, not fiber with switch at every 100 mtrs., will it work ??? or might v any problem?? total distance will be arount 4-5 km
dasvos
Re: i want to spread copper wire in my area, not fiber with switch at every 100 mtrs., will it work ??? or might v any p
Fri Dec 16, 2016 9:39 pm
Why not go fibre? Copper is really not worth rolling out, most customers will prefer Fibre anyway. Even for back bone links Fibre will work better.
docmarius
Sat Dec 17, 2016 4:45 pm
Such things do work. But you will probably need to get new switches after each storm. Or at least change to another working ethernet port, because the used one will be knocked out by lightning, no matter how many precautions you will take.
In the long run, fiber is cheaper.
Torturing CCR1009-7G-1C-1S+, RB450G, RB750GL, RB951G-2HnD, RB960PGS, RB260GSP, OmniTIK 5HnD and NetMetal 922UAGS-5HPacD + R11e-5HnD in my home network.
chechito
Sat Dec 17, 2016 5:03 pm
ethernet in outdoors gives you many problems because of electrical problems
go fiber, maybe https://en.wikipedia.org/wiki/Ethernet_ ... al_network is what you need, check it out
of course if your project is limited to ethernet, use very cheap ehternet switches to make cheaper to repleace it every time they burn
cutedrummerboy
Sun Dec 18, 2016 4:32 am
copper based last mile is too bad idea. you need power for every switch, copper is costly, too much prone to hack and electrical interference. though some isp in my country (india) run such network but its a very bad idea nowadays. fiber is cheap man. go for gpon or atleast gepon.
Device: RB2011UIAS-RM, RB750GL, CISCO SG300-28, UNIFI UAP-LR
Users browsing this forum: Google [Bot], martinclaro and 120 guests
