hamed5034
My router does not working!!!
Tue Dec 20, 2016 11:10 pm
Hello!
I have a problem on my RB951Ui-2nD router.
My router does not working! Its plugged on and it is connected to my PC via a network cable, the PWR and USR LEDs are ON but the port LEDs (1 to 5) are OFF and I cannot connect to router via WinBox.
I cannot reset the router because I have many accounts in user-manager. :(
What should I do?
Regards
Hamed
IntrusDave
Re: My router does not working!!!
Tue Dec 20, 2016 11:27 pm
Have you tried a different network cable, and a different PC?
David Joyce
Network & Security Engineer
Intrus Technologies, LLC.
Rancho Cucamonga, CA, USA
hamed5034
Re: RE: Re: My router does not working!!!
Tue Dec 20, 2016 11:36 pm
Yes I have.
different cable, different PC and different port on router, but does not work. :(
Sent from my Nexus 6 using Tapatalk
IntrusDave
Tue Dec 20, 2016 11:39 pm
sounds like the switch chip failed. You could try a factory reset, but I don't think that will help if the switch has failed.
David Joyce
hamed5034
Wed Dec 21, 2016 12:18 am
So, is it a hardware problem? :(
shahbazian
Trainer
Trainer
Wed Dec 21, 2016 4:07 pm
Hello Hamed,
You may reinstall RouterOS by netinstall. Connect your pc to ether1 and try to use netinstall.
Sent from my SM-G928C using Tapatalk
Learn MikroTik to improve your network.
( MTCNA, MTCRE, MTCWE, MTCTCE, MTCUME, MTCIPv6E, MTCINE )
MikroTik Certified Trainer & Consultant
RIPE NCC Trainer
Users browsing this forum: Google [Bot], MSN [Bot] and 72 guests
