thank u sir for ur reply and adviceIt would better to paste using a terminal client ssh or telnet by recommendation.
I just faced same problem! Solved by using System -> Scripts ->Press Add New
Then you Just paste your commands follow by ; at the end of each line. in the Source text box on the WebFig Page.
Type in your script Name that you want press Apply and press Run Script to start run your commands.
Hope this will help!! ^^![]()
