I am writing to both request help with this configuration and to express frustration with MikroTik Support. I have had a few RB3011s running for a few weeks now and have been unable to properly get the switch chip working on basically any of them. The documentation in the WIKI for the switch chip is atrocious and thus I have been trying to work through it with support. Support has been giving me information which contradicts the WIKI and even today told me that I should hire a consultant if I needed help with the configuration. What I need is functional documentation....
Here is what I am trying to accomplish (which seems trivial)...
Ether01 through Ether10 untagged traffic to bridge local and tagged vlan 2 traffic to bridge-guest. I want to drop all other traffic. I'd ideally like to use the switch chip to get the VLAN part since it will be wirespeed and offload the CPU.
Right now I have Ether2 to Ether5 set with ether1 as their master-port and put ether1 in bridge-local. I have ether7 to ether10 with ether5 as their master port and put ether5 in bridge local. I have vlan2 on bridge-local and put that into bridge-guest. Everything works correctly, but it doesn't use the switch chip. My goal is to convert to using the switch chip.
Thoughts?
