Sob
Dstnat in output chain?
Wed Dec 28, 2016 5:06 am
I thought I knew RouterOS pretty well, but this got me. With Linux iptables, I can change destination for locally originated connections like this:
iptables -t nat -A OUTPUT --dst 192.168.80.1 -j DNAT --to-destination 192.168.84.2
But this does not seem possible in RouterOS. Did I just miss something, or is it known limitation?
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply.
Van9018
Long time Member
Long time Member
Re: Dstnat in output chain?
Fri Dec 30, 2016 2:41 am
It doesn't appear RouterOS will accept a rule like that. Looks like Output rules can't jump to dstnat rules.
Closest you'll get is using just a dstnat rule with src ip of the router to make RouterOS apply it to packets originating locally.
Chain=dst-nat, src-ip=<IP OF ROUTEROS>, dst-ip= 192.168.80.1, to-destination=192.168.84.2
Sob
Fri Dec 30, 2016 5:51 am
It's not important where it is, but what it should do. Trying to use current dstnat chain does not work, it applies only to packets coming to router from elsewhere, not locally originated.
Existing mapping between iptables and RouterOS chains is like this:
"iptables -t nat -A PREROUTING" is "/ip firewall nat chain=dstnat"
"iptables -t nat -A POSTROUTING" is "/ip firewall nat chain=srcnat"
But it looks like "iptables -t nat -A OUTPUT" was skipped by MikroTik. I get it, it's not like it would be an essential functionality for many people. But sometimes it could be useful, e.g. for this guy.
nescafe2002
Long time Member
Long time Member
Tue Jan 31, 2017 3:40 pm
I'd also vote for this option. It could be useful for:
- scoped DNS forwarders; by moving the L7 rules from dstnat chain to forward chain the local DNS server and cache can be used
- local traffic (e.g. netwatch) to netmapped subnet
Sob
Tue Jan 31, 2017 5:09 pm
If this was added, I'd also use it for per-domain DNS forwarding in few places, because it would help with at least some shortcomings of current L7 hack (bypassing cache and not working for router itself). But I really hope to live to see proper support for that in RouterOS DNS resolver.
bajodel
Long time Member
Long time Member
Sun Feb 12, 2017 11:31 am
interesting feature +1
baragoon
Sun Feb 12, 2017 7:21 pm
+1
Отправлено с моего iPhone используя Tapatalk
intelfx
Sun Feb 19, 2017 3:55 am
I'd +1 this feature as well, need it for conditional DNS forwarding too.
forsakenzero
Mon Jan 01, 2018 4:15 pm
hey there. happy new year with my first post!
i need this feature badly, isn't there any way to do this yet?
i can do it by using another RB to work as my first RB's firewall, but this isn't pleasant
juliokato
Thu Jan 04, 2018 2:35 pm
+1!
I apologize my grammatical errors, my english not so good, I am not a native speaker.
Wiki is maintained in English. I use Google translator. 8)
Sob
Wed Apr 18, 2018 1:54 am
After reading sindy's Multiple Road Warrior L2TP/IPsec clients behind NAT - solved thread, and after my brain stopped hurting, I thought "hey, this loop trick could also work for other stuff". The idea is to let traffic from router go out, then let it come back to router and then it's possible to do dstnat. Following example shows how to redirect router's own DNS queries to another port, but you can use it for anything. First mark routing for output traffic you need to dstnat, and then you can match it with in-interface=ipip-loop2 in dstnat chain.
add name=loopback protocol-mode=none
add address=127.0.0.2/32 interface=loopback
/interface ipip
add local-address=127.0.0.1 name=ipip-loop1 remote-address=127.0.0.2
add local-address=127.0.0.2 name=ipip-loop2 remote-address=127.0.0.1
add distance=1 gateway=ipip-loop1 routing-mark=loophack
add distance=1 dst-address=10.10.10.10/32 gateway=ipip-loop2
set allow-remote-requests=yes servers=208.67.222.222,208.67.220.220
/ip firewall mangle
add action=mark-routing chain=output dst-port=53 new-routing-mark=loophack passthrough=no protocol=udp
add action=mark-routing chain=output dst-port=53 new-routing-mark=loophack passthrough=no protocol=tcp
add action=src-nat chain=srcnat out-interface=ipip-loop1 to-addresses=10.10.10.10
add action=dst-nat chain=dstnat dst-port=53 in-interface=ipip-loop2 protocol=udp to-ports=5353
add action=dst-nat chain=dstnat dst-port=53 in-interface=ipip-loop2 protocol=tcp to-ports=5353
add action=masquerade chain=srcnat out-interface=<WAN>
(10.10.10.10 is some random address you don't use anywhere else)
It works, but now my brain hurts again.
aoakeley
Tue Aug 21, 2018 5:23 pm
After reading sindy's Multiple Road Warrior L2TP/IPsec clients behind NAT - solved thread, and after my brain stopped hurting, .........
You sir, are a deadset legend.
I used this to solve an issue with The Dude running on a router, and needing to change the remote winbox port for some sites (which The Dude does not support). I had been beating my head against not being able to dst-nat in the outbound chain for a few hours. I was almost there and this got me the rest of the way.
Sob
Thu Aug 23, 2018 3:27 am
Thank @sindy for this one, I'd never come up with such crazy idea myself. :)
Florian
Thu Apr 18, 2019 3:09 pm
+1, for the same reason, about conditional DNS forwarding.
The loop trick is cool, but honestly I want a simpler solution :D Maybe RoS7 and a new kernel...
- Sorry for my english -
Sob
Thu Apr 18, 2019 10:31 pm
Actually, the loop trick is really dirty trick, but if you're really desperate, it could be used. Simpler solution would be to make dstnat in output available in RouterOS. It shouldn't need new kernel, I found it mentioned in articles about Linux 2.4 and RouterOS has some 3.x, if I remember correctly. So it's most likely there already and they probably just didn't think that anyone would need it, so they didn't expose it.
If you really need it, you can try sending official feature request to support. But if you want it for DNS, then better ask for what you really need and that's Feature Request: Conditional DNS Forwarding. Dstnat in output would be only a workaround, slighly better than what we have now, but still not very good.
Users browsing this forum: No registered users and 103 guests
