Stryker777
Radius
Tue Oct 24, 2006 5:48 am
Just wondering... Is it possible to use radius but still have the secrets entered and enabled so if radius goes down, the default secrets could take over?
From what I have seen, local secrets are default over radius so I have to keep the secrets disabled so radius can authenticate and if radius goes down I have to manually go in and enable them.
sergejs
Tue Oct 24, 2006 8:15 am
Yes, firstly local configuration is consulted then RADIUS server database.
You can add backup RADIUS server, or try to automate described actions (enabling secrets) with scripts.
Users browsing this forum: behrooz and 176 guests
