samrock
GSM/LTE and Mikrotik
Wed Jan 04, 2017 11:35 pm
I am looking for a Mikrotik with Cellular card. I see the RB411U has a SIM slot on board. I cannot locate a list of compatible WWAN 3G/LTE cards. Does any one have a list of compatible cards or has worked with this in the past and can give me information on what card you used.
cutedrummerboy
Re: GSM/LTE and Mikrotik
Thu Jan 05, 2017 4:38 am
Device: RB2011UIAS-RM, RB750GL, CISCO SG300-28, UNIFI UAP-LR
samrock
Fri Jan 06, 2017 12:04 am
Thanks, that is exactly what I was looking for! I already have a few different models in stock that are on that list. Now I am just waiting for the 411u to come in the post...
samrock
Sat Jan 14, 2017 9:58 am
Ok, I got all the parts in today and set it every thing up. I had to search around to find all the info so I am hoping some one has some input for the U.S.Carrier FreedomPop "They are a AT&T MVNO" I am unsure if it is not connecting due to low signal or wrong settings.
I set the card up with:
name="ppp-out1 " max-mtu=1500 max-mru=1500 mrru=disabled port=usb2 data-channel=2 info-channel=1
apn="freedompop.foggmobile.com" pin="" user="*" password="*" profile=default phone="*99#" dial-command="ATDT"
modem-init="AT+CGDCONT=1,"IP","ISP.CINGULAR"" null-modem=no dial-on-demand=yes add-default-route=yes
default-route-distance=0 use-peer-dns=yes keepalive-timeout=30 allow=pap,chap,mschap1,mschap2
Tomorrow I will bring it to a location with a good signal and test again. I am unsure of the proper data channel & info channel settings I have attempted to invert the settings and it does not work either way.
samrock
Sun Jan 15, 2017 1:13 am
Ok, I got it working
int ppp-c pri
name="ppp-out1 " max-mtu=1500 max-mru=1500 mrru=disabled port=usb2 data-channel=0 info-channel=1 apn="freedompop.foggmobile.com" pin="" user="" password="" profile=default phone="*99#" dial-command="ATDT" modem-init="AT+CFUN=1" null-modem=no dial-on-demand=no add-default-route=yes default-route-distance=1 use-peer-dns=yes keepalive-timeout=30 allow=pap,chap,mschap1,mschap2
Users browsing this forum: anon31337, shivanimtneha and 142 guests
