In our wisp we use pppoe-client on cpe devices (lhg,sxt,etc) which runs on top of the wireless interface wlan1. wlan1 is a client of the sector ap.
I have a situation where I want to set up the cpe to terminate the wireless connection,
then have another routerboard (hex poe) terminate the pppoe-client.
Only this is not working.
I know there is Layer 2 connectivity from the access point -> lhg5-> hex, because if I run dhcp client on hex I get an ip from the core router. In contrast, pppoe-client on hex does not do anything. No attempts to connect.
I have tried this using also a dynadish and a 750up, result is the same.
I'm thinking if this could be because I have "default forward" unticked on the access point? If so, is there something else I can do about it,?
