w0lt
Long time Member
Long time Member
RB3011 IPSEC Hardware Encryption?
Sun Jan 08, 2017 7:37 pm
Does the RB3011 have hardware encryption ability and is it enabled?
Thanks,
-tp
MTCNA - 2011
" The Bitterness of Poor Quality Remains Long After the Sweetness of Low Price is Forgotten "
kiler129
Re: RB3011 IPSEC Hardware Encryption?
Mon Jan 09, 2017 1:47 am
It has this in CPU but it's not enabled AFAIK - http://wiki.mikrotik.com/wiki/Manual:IP ... encryption
dhoulbrooke
Mon Jan 09, 2017 7:39 am
Not yet unfortunately:
http://forum.mikrotik.com/viewtopic.php?t=83478#p512868
http://forum.mikrotik.com/viewtopic.php ... 02#p542641
josu
Mon Jan 09, 2017 12:28 pm
Is there any plan to implement it?
It will great to have it in the next release.
Regards.
mrz
Mon Jan 09, 2017 12:29 pm
As it was mentioned in other topics, there will be no HW acceleration in ROS v6.
Ascendo
Tue Jan 10, 2017 8:19 pm
How much IPSEC throughput can it do currently (software only)?
efaden
Sun Jan 15, 2017 10:10 pm
Curious myself....
infused
Wed Jan 18, 2017 8:45 am
bugger all.
chriscolden
Sat Jun 30, 2018 11:16 am
I'm seeing about 16Mb over the internet at about 7 or 8% cpu over all. The internet the other end is limited at 20Mb upload so I cannot physically receive any faster anyway.
petrz
Tue Sep 18, 2018 12:08 pm
What's new in 6.43.1 (2018-Sep-17 06:53):
Changes in this release:
*) rb3011 - added IPsec hardware acceleration support;
zorrua
Tue Sep 18, 2018 10:48 pm
Great!
Is there any example about how to configure a IPSec tunnel between 2 RB3011 devices?
Kind regards.
honzam
Tue Sep 18, 2018 11:06 pm
Really? :)
LAN, FTTx, Wireless. ISP operator
sindy
Wed Sep 19, 2018 4:53 pm
There is nothing specific for the case of two RB3011, simply use the setup for any two Mikrotik devices mentioned in the manual. If hardware support for the authentication and encryption algorithms chosen is available on the device, it is activated automatically - it does not need to be switched on, and it cannot be switched off. Which algorithms enjoy hardware support can be found in this table in the same manual.
Instead of writing novels, post /export hide-sensitive. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
gcxo
Mon Sep 24, 2018 1:53 pm
I've install 6.43.1 on a 3011 but the IPSEC HW accelartion does not seem to work, it works fine on 750r3 an 1100ahx2.
Installed SAs of the 3011
Installed SAs of the 1100
One of the conexion is between the 1100 and 3100. On the 1100 side has EH, but on the 3011 has only E.
Any ideas?
bennyh
Mon Sep 24, 2018 2:12 pm
For first sight might the problem is:
* supported only 128 bit and 256 bit key sizes
On your captured picture is see 192 bit size encription keys.
Any ideas?
sindy
Mon Sep 24, 2018 2:14 pm
In the table in the manual, there is a * reference in the row for RB3011, which says
In your installed-sa list, I can see "192" in "Encryption Key Size" column. So change the aes key size to either 128 or 256 bits and try again.
gcxo
Tue Sep 25, 2018 11:58 am
Thanks!! Setting the default ipsec proposal only to allow 128 or 256 worked.
emils
Wed Oct 03, 2018 11:08 am
What's new in 6.44beta14 (2018-Oct-01 12:01):
*) rb3011 - implemented multiple engine IPsec hardware acceleration support;
IPsec throughput table for RB3011UiAS-RM on our products page is updated too.
https://mikrotik.com/product/RB3011UiAS ... estresults
If you experience any stability related issues when running hardware offloaded IPsec on RB3011UiAS-RM, please let us know at support@mikrotik.com
Users browsing this forum: Baidu [Spider], Google [Bot], Janncsi, sindy and 174 guests
