MUM Europe 2020
djape
Scheduler problems - attn. MT support
Thu Oct 26, 2006 12:04 am
I use schedullers big time.
Few months ago I have posted a problem with scheduller not exectuning at all.
Somehow I tried everything and found that scheduler is working if I change start date to current (which leaves me to change it every morning).
It was not a big trouble cause it was just a few MTs on my network and rest of them (various 2.9 versions) where working properly.
But yesterday I upgraded all to 2.9.34 and not even a single one executed schedulles?! RB532, rb112, a PCs all together :(
Now I'm in trouble as I need to execute scripts manually on more than 50 routers.
This was posted before from different members and never taken seriously by MT team.
Please, can someone investigate a problem.
I can send suppout from all MT's but somehow don't see how would that help. It's a simple p2p accept and drop schedulle...
Thx
djape
I drink like a pirate and smoke like a hippie...
sergejs
Thu Oct 26, 2006 8:35 am
djape, you need to send support output file which includes scheduler configuration to the MikroTik support.
djape
Thu Oct 26, 2006 6:15 pm
Ok, supout and exports from scripst and scheduler are sent today.
I hope you guys will locate the problem.
Thx...
odie
Thu Oct 26, 2006 6:45 pm
i have the same problem here on differnet versions of 2.9 - if i set the start time to the actual date then it normaly works until i reboot the box
then no more scedueled script is started - after setting the date back to the actual date it works again ...
so do not reboot the boxes ;-))
Seccour
Thu Oct 26, 2006 10:50 pm
use NTP to keep the date and time on the boxes. Then you don't need to manually go in and reset the date and time if the box gets rebooted.
djape
Fri Oct 27, 2006 11:30 am
Read more carefully, he don't have problem with system time. Problem is start date in scheduller. I have the same problem. If I set system current date scheduller will work, but tommorow it will not if don't change start date again to tommorows date.
Sorry to say, but I find this to be very serious bug.
changeip
Fri Oct 27, 2006 6:21 pm
Which version is this not working on? .31 works here. I will try to change 00:00:00 to something else to see what happens.
 #   NAME      ON-EVENT  START-DATE  START-TIME INTERVAL             RUN-COUNT
 0   backup1   e-backup  jan/01/1970 00:00:00   1d                   9
 1   backup2   e-config  jan/01/1970 00:00:00   1d                   9
 system resource> print
                   uptime: 1w1d23h41m25s
djape
Sat Oct 28, 2006 4:47 pm
It's 2.9.34
Never used 2.9.31 but same thing is on 2.9.28 which I used before upgrade. I can't recall in what version this problem was introduced. But it was few months ago, and I try to upgrade regularly.
normis
Mon Oct 30, 2006 2:42 pm
based on your report, we have fixed the following bug:
if until the next scheduled time, the remaining time is less than interval/2 - then after set and reboot, the scheduler was skipping one run time (it would have started the day after tomorrow).
djape
Mon Oct 30, 2006 3:51 pm
Thx normis, I have never doubt that you guys will find the problem :wink:
Keep up the good work :)
Cheers...
djape
Mon Nov 06, 2006 4:06 pm
I'm happy to say that this is fixed in 2.9.35 :)
Cheers folks ;)
rgraham
Thu Nov 16, 2006 9:50 pm
I am running 2.9.35 and my schedule jobs did not start back up on their own after rebooting.
rgraham
Thu Nov 16, 2006 10:25 pm
I don't know what was done but when I configure and event in the Scheduler for Nov/18/2006 at 01:00:00 the Next Run time says Nov/17/2006 1 18:31:44.
normis
Fri Nov 17, 2006 9:55 am
i think you configuration is wrong, make a new topic and post your configs.
janisk
Fri Nov 17, 2006 10:15 am
about sceduler - try not to use start time: startup, if you do, check if next start date ir correct, if not, recreate the rule with some other time. :roll:
Users browsing this forum: ceres, Google [Bot], MSN [Bot], stevan90 and 114 guests
