MUM Europe 2020
conchalnet
Renew IP address of PPPoE client
Tue Jan 17, 2017 3:14 pm
I need to change an IP address of one customer that is connected to our network throught a PPPoE server configurated on a CCR1036. But every time the customer connects the Mikrotik give him the same IP address!
How can I force the Mikrotik to renew the IP address of PPPoE connections on every reconnection???
Regards
Fabrício
boardman
Re: Renew IP address of PPPoE client
Thu Dec 06, 2018 12:28 am
Did you ever found the solution for this?
Best
evince
Thu Dec 06, 2018 12:37 pm
try to first remove his entry in the DHCP Lease, and then reconnect it.
boardman
Thu Dec 06, 2018 7:29 pm
Thanks for your reply, but this is PPPoE not DHCP, IP's are taken from an IP-pool, not DHCP
Still stuck on this one.
Best
amt
Long time Member
Long time Member
Fri Dec 07, 2018 10:41 am
Regards
Fabrício
divide your ip pool in many pool, I tested before and its change when device disconnect and connect again
boardman
Sat Dec 08, 2018 4:42 am
Thanks for your answer,
What do you mean with "I tested before and its change"
"divide your ip pool in many pool, I tested before and its change when device disconnect and connect again"
Sorry, I don't understand what you mean, I understand on how to divide into many pools but the rest of the phrase I don't.
amt
Long time Member
Long time Member
Sat Dec 08, 2018 9:39 am
I mean if you use /24 for pppoe pool divide it to /25 and create 2 x ip pool and use next pool option
here is an example
add name=PPPoE_Pool-1 ranges=100.64.16.0/25  next-pool=pool1
add name=pppoe_pool-2 ranges=100.64.16.128/25
boardman
Sat Dec 08, 2018 10:56 pm
Thanks, will try this.
ciberica
Sun Dec 09, 2018 8:51 am
Hello friend, how have you managed to change the ip every so often to pppoe customers?
boardman
Mon Dec 10, 2018 10:45 pm
Haven't tried it yet...
ciberica
Sun Jan 06, 2019 5:05 am
thank
Users browsing this forum: ilja, naxos and 115 guests
