ik3umt
CAPsMAN what if....
Fri Jan 20, 2017 11:11 am
What if I install more wAP-ac controlled by CAPsMAN without any channel configuration ??
Do they place themselves in a random channel each ?
Thank you
uldis
Re: CAPsMAN what if....
Fri Jan 20, 2017 11:36 am
on startup they will do auto frequency selection so most likely it will select different channel.
ik3umt
Fri Jan 20, 2017 2:59 pm
So....it seems NOT working on wAP-ac 2.4GHz radio, I thougth it was a CAPsMAN issue but tried to run wAP-ac as normal AP : SSID is not seen by my 2.4GHz devices.
Band : 2GHz b/g/n
Channel Width: 20MHz
Frequency: Auto
SSID sometimes pops-up for few seconds and disappears
If i set frequency, it appears rock solid and wireless connection is established correctly.
Any idea ?
uldis
Fri Jan 20, 2017 3:21 pm
Please upgrade the RouterOS on wap ac to v6.39rc15 as there are some improvements for wap ac in 2.4ghz.
About the ssid now showing up - check the status on the cap interface in the CAPsMAN what channel it selected.
nz_monkey
Sun Jan 22, 2017 4:22 am
There are none listed in the 6.39rc15 change log :(
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
andriys
Sun Jan 22, 2017 7:43 pm
6.39rc ChangeLog on the download page appears to be incomplete. This fix was mentioned in the ChangeLog for 6.39rc4, check it out here.
Users browsing this forum: MSN [Bot] and 115 guests
