himvas
Winbox empty (Resolved)
Thu Feb 02, 2017 9:38 am
I have RB3011. It's working fine, but when I connect by Winbox it shows all pages empty (no interfaces, no addresses and so on).
For SSH connection I can see all.
Also I have some wAPs - WInbox connection for them works fine.
I connect to IP address, not MAC.
WInbox version 3.10.
I deleted 'Mikrotik' folder from AppData - it didn't help.
p3rad0x
Long time Member
Long time Member
Re: Winbox empty
Thu Feb 02, 2017 11:16 am
Does it stay blank and then disconnect from winbox?
There you go then you touched something ;-) : it only takes a change in wind direction to screw with your nat :-)
strods
Re: Winbox empty
Thu Feb 02, 2017 1:31 pm
In Winbox loader use Tool/Clear Cache and then try to connect again.
himvas
Re: Winbox empty
Thu Feb 02, 2017 4:01 pm
Problem resolved.
Source was in network adapter in my computer.
All was fine till today morning, when problem began, I don't know what triggered it - there was no changes for some months.
But when I turn off all default turned on offloads for TCP/IP in onboard Realtek based network card problem disappears.
Also, as a symptom, - when I clear Winbox cache, program began to download plugins and it was VERY slow - about 1 Kbyte/s ! And this for Gigabit LAN!
Mikrotikate
Re: Winbox empty (Resolved)
Mon Apr 27, 2020 3:54 am
Based on my experience, the reason for this behaviour may just be bad 802.11n support, on 2.4Ghz wlan interfaces.
I have spent most of this weekend trying to understand the cause for this behaviour.
I'll spare you the headache. Here is a list of symptoms, what i tried to do, and the final solution.
List of symptoms:
1. While connecting using winbox to the ip/MAC, winbox is stuck at "Downloading descriptors"
2. When it connects, most of the time existing session windows are empty
3. When it's connected, opening a new terminal window returns nothing
4. Random winbox disconnects
5. High weird network latencys
6. Some WebPages (not Google) take a lot of time to open, and most of the time they don't open completely.
What i have tried to do:
1. RB reset
2. Tried several bridge/no bridge configurations for wlan1
3. Tried MAC Connection/IP Connection, all the same.
4. Tried clearing the "Appdata" folder and "clear cache" in Winbox loader, al lthe same.
5. Firmware upgrades to latest 6.45.8
6. Package upgrades to latest 6.45.8
7. Configuration reset, without default configuration.
Started from scratch and added only wlan1 in "default settings"
8. Tried exchanging the power supply, to another with 24V/1200ma, same thing, so its not the power supply.
9. I have 3 hap AC, updated all to the last 6.45.8, same problem in all of them, so it's not bad hardware/power supply.
10. Tried removing wlan chains, and leave just one chain, no help.
11. Used another computer to connect, same issue, so its not the computer.
12. Finally tried to disable 2.4Ghz "N" Band Modes. BINGO.
The final solution:
Don't use 802.11n on 2.4Ghz Mikrotik Interfaces.
Problem gone, low latency network and stable connection with 2Ghz-only-G.
dakotabcn
Fri Nov 13, 2020 4:30 pm
Hello
I have this problem, i connecta via VPN L2TP and have this problem
I not use Wifi, via local lan works fine, via VPN show empty, this router not have wireless
any idea?
aryalee
Sat Nov 21, 2020 10:54 pm
Hi
Update 1:
The problem was large MTU set between two routers and since I was connecting to R2 through R1, I got disconnected continuously. I reduced MTU and problem solved.
Original Post:
I just did the laziest thing I could.
1. Connected via Winbox and so many empty windows like "ip route", "ip addresses", ... inside Winbox opened.
2. From "Session" menu I chose "Close All Windows" and then I exited Winbox.
3 Connected to Winbox again and everything was fine :)
Users browsing this forum: anav, coreshok, kivimart, mrtrca, xvo and 29 guests
