chrisbren
Mikrotik Package not installing
Sat Feb 04, 2017 4:45 pm
I can't install package (usermanger or any package) in mikrotik, I have updated the firmware to v6.38.1 which is the latest currently, i have dragged and dropped the package is in file window but its not loaded to the package directory in winbox, i have also used ftp to transfer the file but non is working.
package is the version with mikrotikos
also using winbox v3.10
td32
Re: Mikrotik Package not installing
Sat Feb 04, 2017 5:23 pm
did you reboot after that?
A reboot is necessary.
chrisbren
Mon Feb 06, 2017 8:26 am
I reboot after loading the package. It still didn't show in the package directory.
lambert
Long time Member
Long time Member
Mon Feb 06, 2017 8:50 am
Is the package file still in the files listing after the reboot?
What architecture is the router? mipsbe, tile, powerpc, x86? For what architecture was the package file built?
Uploading packages for the wrong architecture is probably the most common reason for problems like this. Corrupt uploads are probably number two. Please show us the results of running the following command in a terminal window:
/file print
chrisbren
Mon Feb 06, 2017 6:19 pm
That was my bad, i downloaded x84 instead of MIPSBE architecture.
mc4u
Mon Jul 16, 2018 11:57 pm
Hello evening sir. I have same Challange with my microtik RB433.
I have done copy and paste several time in order to load the users manager under packages and I reboot but still not showing users manager and the architecture I downloaded for it is mipsbe.
Kindly advice me on what to do
lambert
Long time Member
Long time Member
Tue Jul 17, 2018 4:38 pm
What does the log say immediately after reboot?
Ubiifere
Fri Jul 20, 2018 10:56 am
I have this same issue on rb951 trying to load package with the intent to downgrade to lower Ros. The files will be on my file list but never load into device after reboot? Any hints guys
mkx
Fri Jul 20, 2018 11:11 am
To downgrade ROS version, it's not as simple as to upgrade. In addition to put required package files to the device, one has to issue command
/system package downgrade
Or so does the manual say.
BR,
Metod
Users browsing this forum: No registered users and 30 guests
