emikrotik
SFP Interfaces
Thu Feb 16, 2017 9:52 am
I am using a CRS212 with two uplinks to a CRS226,
I am using a S-31DLC20D on both sides from the CRS212 to the CRS226 SFP+ 1.
Based the SFP comparability matrix; http://wiki.mikrotik.com/wiki/MikroTik_ ... lity_table the S-31DLC20D are not compatible with the CRS226 SFP+ 2 port.
I am going to purchase S+85DLC03D to use on the CRS226 SFP+ 2 port, with this work when connected to the CRS212 via S-31DLC20D?
Thank you.
karlisi
Re: SFP Interfaces
Thu Feb 16, 2017 10:09 am
You should use similar SFP modules on both ends of optical link. These modules are very different, S+85DLC03D is 10Gbps 850nm multi mode, S-31DLC20D is 1.25Gbps 1310nm single mode.
Karlis
marklylelk
Re: SFP Interfaces
Fri Feb 17, 2017 4:48 am
This is an old question about whether a SFP module can work on the SFP+ port. The answer is "in most cases, SFP Can be Plugged into SFP+ Ports", but you have to configure the interface before inserting the SFP. Sometimes you have to tell the switch/router vendors that the port is going to run at 1000 megabit before you insert the SFP..
Nice article. please see: http://opticalfiberalsa.over-blog.com/2 ... ssues.html
Hope it helps!
lisachang001
Location: Suzhou Industrial Park, Jiangsu Province, China
Re: SFP Interfaces
Thu Jun 22, 2017 6:41 am
That's right, same wavelength and datarate can be communicated, so you should use the same one model on both slots.
https://www.optcore.net
One-stop supplier of SFP/XFP/SFP+/QSFP Transceiver and Media Converters.
Users browsing this forum: dikrek and 62 guests
