sawireless
MikroTik switches off/on
Sun Nov 05, 2006 2:42 pm
We have just installed a new base station on a tower that is 45meter up; we did find a power issue with POE 45 volts, we then run a 220 power cable up the tower with the transformer inside the box, but we are still having the same problem that the unit switches 0ff/on .We went back to Miro and sat there for 1½ hours and got the unit to work, we then run the unit for a day and ½ with no problems. But as I said we put the unit back, it started the problem of switching off/on
The unit that we are running is the 532 +502+3 X NMP-8602 PLUS
1: earth leak ?
2: interference from two way radio ?
3: interference from ADT, CHUBB, FSK Repeaters ?
skillful
Trainer
Trainer
Sun Nov 05, 2006 3:33 pm
The power requirement of 3 X NMP-8602 PLUS is too much for RB532 to handle. You have to Remove one of the NMP-8602 PLUS for the 532 to be stable.
sawireless
Sun Nov 05, 2006 4:42 pm
so you are saying that I can run 2 X NMP-8602 PLUS and 1 x CM9 ?
sergejs
Mon Nov 06, 2006 8:33 am
System might be unstable with 2 High power cards and one regular card (there were some reports about the particular high power wireless card in the wireless forum).
2 High power cards should work fine in RB500.
Users browsing this forum: Bing [Bot] and 207 guests
