michalsz2
DHCP error after reboot
Wed Mar 01, 2017 3:16 pm
I’ve been using mikrotiks at my clients for few years now.
In this new place I have couple month’s old Hex2 5 port router.
2 weeks after install every time after a reboot DHCP doesn’t work right.
Logs show multiple instances of “ dhcp1 offering lease: ip: for :mac: without success”
And no device on dhcp can work.
Only way to fix it is to disable and re-enable dhcp server.
Is this a known issue? And is there permanent fix for it?
michalsz2
Re: DHCP error after reboot
Thu Mar 02, 2017 2:38 pm
Any ideas?
blajah
Thu Mar 02, 2017 3:15 pm
Whats your DHCP config? Is it authoritative ?
I have bigger routing table.
arxdust
Thu Mar 02, 2017 6:40 pm
which version ROS you use?
michalsz2
Sat Mar 04, 2017 1:31 am
Im using 6.38.3, I was couple behind when issue started, update didn't fix it.
Every time I reboot the mikrotik Im getting that error from all devices on the network, until I disable and re enable DHCP server.
Mike
michalsz2
Wed Mar 08, 2017 2:34 pm
What does it mean authoritative DHCP?
arxdust
Wed Mar 08, 2017 9:52 pm
Users browsing this forum: No registered users and 134 guests
