mehran
RouterOS 6.38.3's LLDP Craches Vulnerable Cisco Routers
Fri Mar 03, 2017 5:03 am
I'm just trying to give heads up for those who may be affected.
Today one of our X86 machines have been updated to version 6.38.3 and after that both uplink Cisco routers started a crash loop.
After investigation noticed LLDP triggers a bug in some of the IOS versions.
The version that we were on was 12.2(33)SXI3
The only solution for us was to disable LLDP on the routers.
https://bst.cloudapps.cisco.com/bugsear ... SCtj22354/
https://bst.cloudapps.cisco.com/bugsear ... SCun63132/
https://tools.cisco.com/security/center ... 160616-ios
Following is the debug output from crash dump:
(gdb) print *entry
$18 = {
  next = 0x0,
  prev = 0x0,
  idb = 0x0,
  rxInfoTTL = {
    mt_next = 0x0,
    mt_prev = 0x0,
    mt_head = 0x0,
    mt_union = {
      mt_down = 0xaaaaaaaa,
      mt_context = 0xaaaaaaaa
    mt_exptime = {
      u = {
        value = 0,
        p = {
          high = 0,
          low = 0
    mt_type = 0,
    mt_initialized = 0 '\000',
    mt_fence = 0 '\000',
    mt_leaf = 0 '\000',
    mt_istimer = 0 '\000',
    mt_sched_linked = 0 '\000',
    mt_proc_notify = 0 '\000',
    mt_intrpt_env = 0 '\000',
    mt_additional_context = 0x462abf90
  chassis_id = {
    basic_tlv = {
      value = 0x49911edc "",
      length = 7,
      type = 1 '\001'
    subtype = 4 '\004'
  port_id = {
    basic_tlv = {
      value = 0xaaaaaaaa "\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252"...,
      length = 7,
      type = 2 '\002'
    subtype = 5 '\005'
  mgmt_addrs = 0x52638a00,
  remote_med_annex = 0x52638b40,
  port_descr = 0x47fa0be4 "",
  sys_name = 0x48d4ae74 "\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252\252"...,
  sys_descr = 0x52637e8c "MikroTik RouterOS 6.38.3 (st\252\252\252\252) x86",
  ttl = 43690,
  capabilities = 0,
  somethingChangedRemote = 0,
  port_vlan_id = 0,
  num_ma = 10 '\n',
  mau_type = 0,
  pmd_auto_neg = 0,
  auto_neg = 0 '\000',
  hash = 0 '\000',
  known_entry = 0 '\000'
Hopefully this helps someone
Sob
Re: RouterOS 6.38.3's LLDP Craches Vulnerable Cisco Routers
Fri Mar 03, 2017 11:30 am
"MikroTik, the Cisco killer" - sounds sort of nice, although one would expect it to be just a little exaggerated praise of MikroTik qualities, not a literal thing. :)
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply. Not intended as incentive for masochists.
Thalid
Sat Mar 04, 2017 10:55 am
Kinda old Vulnerable shure there must be upgrade from cisco out if your router is still supported
Getting cisco ios is easy even whitout an support deal
Chupaka
Sun Mar 05, 2017 10:56 pm
Cool, that's not the first time MikroTik kills Cisco. Previous one was with BGP AS Path > 254 ASes, AFAIR :)
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
kd6icz
Thu Mar 09, 2017 5:55 am
Could this cause other devices to crash? I'm not a router expert and all my stuff is in my home.
I use Windows Media Center and last night I was watching TV and it just stopped.... After 30 seconds or so the Xbox said it lost it's network connection. I logged into the IMPI of my server (connected directly to my 3011 router) and the OS was locked up solid. The server payload traffic is connected to my 226 switch via 10Gbps fiber.
So it appears that something happened in the switch to cause a halt in all packets.
I just noticed .4 was available so I upgraded hoping this issue goes away.
Sent from my XT1650 using Tapatalk
kd6icz
Tue Mar 14, 2017 5:21 am
.4 didn't resolve this issue. So I rolled back to the Bug Fix only 6.37 build and everything has been up and trouble free for over 3 days now.
I ran into a similar issue last year when I was using a Netgear switch. All was good until they "fixed" something in a firmware update. Rolling it back cleared it up too.
mrz
Wed Mar 15, 2017 11:21 am
And how is this a Mikrotik bug? You should upgrade your Cisco router instead.
kd6icz
Thu Mar 23, 2017 5:34 pm
I've been steady for two weeks after rolling back to 6.37.5 on my switch so.... Good job Mikrotik for screwing up something that was working fine. Looks like my CRS-226 won't be getting anymore updates.
Sob
Fri Mar 24, 2017 12:56 am
So, you have a server, it receives LLDP packet from RouterOS and locks up. And it's MikroTik's fault (and Netgear's too, lets not forget about them) for sending out packets that server does not like. Definitely not server's fault for failing to correctly process input.
Maybe it's just me, but locking up at the mere sight of some packet - no matter how much the server doesn't like it, for any reason - sounds extreme to me, and I would probably tend to blame the server. ;)
kd6icz
Re: RE: Re: RouterOS 6.38.3's LLDP Craches Vulnerable Cisco Routers
Fri Mar 24, 2017 5:36 pm
I have no idea what you just said.... All I know is something in recent firmware upgrade doesn't get along with Windows Media Center.
Users browsing this forum: aanjaneyam, Bing [Bot], BrainPain, Tdaddysimi and 58 guests
