Megamau
LTE USB modem not listed in ports - hEX RB750Gr3
Fri Mar 03, 2017 3:53 pm
I've bought an hEX RB750Gr3 router (upgraded to v6.38.3 routeros) and I am trying to get my 4g usb modem from Vodafone (ZTE R216-Z) work with it.
The modem it's listed under resources but not under ports:
[admin@MikroTik] > system resource usb print
 # DEVICE VENDOR                   NAME                   SPEED
 0 2:1    Linux 3.3.5 xhci-hcd     xHCI Host Controller   5000 Mbps
 1 1:1    Linux 3.3.5 xhci-hcd     xHCI Host Controller   480 Mbps
 2 1:3    Vodafone(ZTE)            Vodafone R216-Z        480 Mbps
[admin@MikroTik] > port print
Flags: I - inactive
 #   DEVICE NAME                     CHANNELS USED-BY                   BAUD-RATE
Is there any trick to get the modem to show up under ports?
I will be glad if someone can help me.
Requium
Re: LTE USB modem not listed in ports - hEX RB750Gr3
Tue Mar 14, 2017 2:45 am
Same here, I tested with a RBhAP AC lite and it list it as device, but it doesnt appear to work on RB750GR3
Any word about this?.
Thanks in advancement
BR
Requium
Megamau
Fri Mar 17, 2017 10:30 pm
Today I was checking ROS 6.39rc55 changelog and saw that they added support for R216. Maybe this device isn't so different from the R216-Z.
Can you check if it fixes? For the next few day I'll be not able to test by myself.
Regards
sityu
Thu Jun 17, 2021 12:38 am
Flags: I - inactive
You can't find, because it uses the LTE interface. Otherwise it works well (15mbps/30mpbs)
Users browsing this forum: kormenator and 159 guests
