MUM Europe 2020
matiaszon
Not showing the origin IP
Sun Mar 19, 2017 12:42 am
So I have a server in my LAN behind mikrotik router. If the peers connected to the router are from LAN (I have two LAN ranges 10.10.10.0/24 and 192.168.83.0/24 configured), then on this server I can see their real IPs. If the connection comes from the Internet (WAN) side, I can see only the IP of the router (10.10.10.1) at each connection. What may be wrong?
docmarius
Re: Not showing the origin IP
Sun Mar 19, 2017 12:58 am
Nothing is wrong. You probably have SNAT/Masquerade enabled on the LAN interface.
Torturing CCR1009-7G-1C-1S+, RB450G, RB750GL, RB951G-2HnD, RB960PGS, RB260GSP, OmniTIK 5HnD and NetMetal 922UAGS-5HPacD + R11e-5HnD in my home network.
matiaszon
Sun Mar 19, 2017 1:06 am
Well, I have masquarade on ether1, which is used as WAN port. But I can't say what I have changed that I cannot see real IPs any more...
docmarius
Sun Mar 19, 2017 1:08 am
Could you post your firewall configuration?
matiaszon
Sun Mar 19, 2017 1:17 am
Here it is...
add action=accept chain=forward comment="LAN Traffic" connection-state="" \
    dst-address=192.168.83.0/24 src-address=10.10.10.0/24
add action=accept chain=forward dst-address=192.168.1.0/24 src-address=\
    10.10.10.0/24
add action=accept chain=forward comment="defconf: accept established,related" \
add action=drop chain=input comment="defconf: drop all from WAN" \
    in-interface=ether1
    connection-state=invalid
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
    connection-state=new in-interface=ether1
add action=drop chain=input comment="DNS drop" dst-port=53 in-interface=\
    ether1 protocol=udp
add action=drop chain=input dst-port=53 in-interface=ether1 protocol=tcp
add action=masquerade chain=srcnat comment="Maskarada WAN"
add action=dst-nat chain=dstnat comment="futro" dst-port=2502 fragment=\
    no in-interface=ether1 protocol=tcp to-addresses=10.10.10.5 to-ports=2502
The port forwarded to the server is 2502.
matiaszon
Sun Mar 19, 2017 1:26 am
OK, so I know what I did.
Look at the last post of THIS TOPIC.
I have deleted ether1 as out interface in masqueade. When I added it again, IPs started to appear correctly...
matiaszon
Sun Mar 19, 2017 3:48 am
I know I am writing to myself, but after I added out interface ether1 some of the peers can't connect getting "connection time out" info. Once I delete ether1 - all are connecting immediately. What the...?!
docmarius
Sun Mar 19, 2017 10:49 am
All outgoing traffic, including the one passing dnat will obey the srcnat chain.
So the issue is this rule:
This will do srcnat on ALL interfaces. You need to do this only on WAN:
add action=masquerade chain=srcnat out-interface=ether1 comment="Maskarada WAN"
On the other hand,
    ether1 protocol=udp
are useless since you already drop all input on eth1 by
    in-interface=ether1
Remember, firewall rules are evaluated in order.
BTW, Oscam supports IPv6 8)
matiaszon
Sun Mar 19, 2017 4:06 pm
As you may noticed, I am a greenhorn regarding MikroTik. Thanks for posting. I started to do some cleaning. :) That DNS rule was made before... I will delete it.
As it comes to IPv6 I believe, that ISP has to provide that too? Anyway, I don't know anything about IPv6 :P
I added out interace for masquerade, but then some peers couldn't connect at all... I couldn't figure out what the problem was, so after 3 hrs I rebooted MikroTik and debian and it started to work... :shock:
docmarius
Sun Mar 19, 2017 6:08 pm
That has a simple explanation. There are lingering connection tracking connections which are not deleted when you change your firewall rules, especially when changing dst-nat stuff.
Rebooting clears those connections...
Users browsing this forum: Google Feedfetcher, MSN [Bot] and 131 guests
