SpartanX
No response after connecting to command line
Tue Mar 21, 2017 2:25 am
I have just updated my 850Gx2 to v6.38.5 and no longer get a response when I log in via SSH, or even from the Webfig Terminal. Webfig itself works fine. I have rebooted the router, several times, and done a real power cycle too.
My login is accepted in SecureCRT, but then there is no response to my typing. In SecureCRT, it takes about a full minute for the Mikrotik banner to show after connecting. I once got a banner in Webfig Terminal, but only once in several attempts. After that, there is still no response to anything I type. No cursor... nothing. I can see what I type but that's all. I tried in UtlraEdit Studio and that actually crashed when I tried to connect!
It was working fine a few days before the update and I did not change anything on the router apart from updating RouterOS. There is nothing in my firewall rules that would stop it, and anyway, I can actually connect initially (and get the login banner if I wait long enough) but it seems the router then just ignores me.
Any ideas?
This is what I get after connecting with telnet in SecureCRT (I don't even get this much in Webfig Terminal)...
  MMM      MMM       KKK                          TTTTTTTTTTT      KKK
  MMMM    MMMM       KKK                          TTTTTTTTTTT      KKK
  MMM MMMM MMM  III  KKK  KKK  RRRRRR     OOOOOO      TTT     III  KKK  KKK
  MMM  MM  MMM  III  KKKKK     RRR  RRR  OOO  OOO     TTT     III  KKKKK
  MMM      MMM  III  KKK KKK   RRRRRR    OOO  OOO     TTT     III  KKK KKK
  MMM      MMM  III  KKK  KKK  RRR  RRR   OOOOOO      TTT     III  KKK  KKK
  MikroTik RouterOS 6.38.5 (c) 1999-2017       http://www.mikrotik.com/
[?]             Gives the list of available commands
command [?]     Gives help on the command and list of arguments
[Tab]           Completes the command/word. If the input is ambiguous,
                a second [Tab] gives possible options
/               Move up to base level
..              Move up one level
/command        Use command at the base level
I can type, but it is completely ignored and I don't get the cursor...
See?
pukkita
Trainer
Trainer
Re: No response after connecting to command line
Sun Mar 26, 2017 3:54 pm
Do you have any other RB connected in layer 2 with the 850?
Have you tried putty or any linux ssh client?
Simplicity is the Ultimate Sophistication - Da Vinci
Getting the most out of this forum
Users browsing this forum: MSN [Bot] and 28 guests
