infgrp
routing between two interfaces with ips from the same subnet
Sat Nov 11, 2006 2:24 am
I have two ethernet interfaces with different Ip from the same subnetwork
ether1 - 10.1.1.2/24
ether2 - 10.1.1.3/24
they have the same gateway 10.1.1.1/24
How can i force different packets to pass via specific interface?
ex: all HTTP (80) packets to pass via ether1 interface to 10.1.1.1 gw,
and all other packets to pass via ether2 interface to 10.1.1.1 gw
Diagram:
________/ ether1 -----\
user - MK____________HUB----GW 10.1.1.1
________\ ether2 -----/
Note: (_) - just a space
balimore
Forum Veteran
Forum Veteran
Re: routing between two interfaces with ips from the same su
Sat Nov 11, 2006 5:01 am
Diagram:
Hello Friend,
I think better your scnario change difference subnet,..!!!
on routerOS is not valid, when you did put same subnet on two or many interfaces,
When your suggestion plain like this[your diagram], you must 'BRIDGE' methode and put IPs on 'BRIDGE'
regards
Hasbullah.com
infgrp
Sat Nov 11, 2006 12:33 pm
May be there any other posibilities to indicate on what interface to be router?
this must work on the interfaces with ips from the same subnetwork. I understand that it is not allowed by the networking rules, but i have to do it.
If not Mikrotik, may be other OS or Hardware can do this?
Thanks a lot
My question is something from advanced routing... not just a mistake in subnetworks
Thanks again
GWISA
Sat Nov 11, 2006 4:15 pm
Is the gateway the same hardware or two different gateways with the same IP?
If it is the same hardware, why use two different paths?
If it is two different machines with the same IP, why use the same IP?
balimore
Forum Veteran
Forum Veteran
Sat Nov 11, 2006 4:46 pm
i think, he put two interfaces for one gateway and one subnet too...!! and difference IP every NIC-interface
so, sorry when i am wrong for thinking... :wink:
regards
Hasbullah.com
infgrp
Sat Nov 11, 2006 4:56 pm
Yeah man, you are right..
This is like a simulation of two PC with different IP in the same subnet.
So, Mikrotik accept to add two different IP from the same subnet to different interfaces.
so, the aim is just to force MK to route the traffic via specific interface regarding some rules (like port 80 via one interface, and else via second interface)
Please, don't ask me why i have to put the same subnet on two interfaces... Just i need it.
Thanks a lot
balimore
Forum Veteran
Forum Veteran
Sat Nov 11, 2006 5:02 pm
peace all :wink:
infgrp
Sat Nov 11, 2006 11:52 pm
any ideas? :)
GWISA
Sun Nov 12, 2006 1:00 am
Thanks a lot
WHy the cloak and dagger attitude? Is this like secret FBI stuff or something?
I think if we understood your intention, we could better help with a solution...
infgrp
Advanced routing
Mon Nov 13, 2006 5:42 pm
There are an DHCP server on the ISP. It gives IP on the DHCP client request.
In normal mode, a few PC can get ip via this DHCP server. All ip are from the same subnet like 10.1.1.0/24
I have to emulate several PC using one MK (Router OS).
Mikrotik (Router OS) have several interfaces, connected to the same DHCP Server. Each interface gets one IP from DHCP server. But all IP are from the same subnetwork. It was no problems at this step.
The problem, is how to rute traffic via specific interface?
Like to mark (via mangle) packets, and to force them to go via specific interface.
Thanks for helping....
GWISA
Mon Nov 13, 2006 9:26 pm
do you need to specifically route traffic, or load-balance it?
infgrp
Tue Nov 14, 2006 12:22 am
It will be great the both :)
Especialy specific routing...
Thanks man!
infgrp
Tue Nov 14, 2006 3:05 pm
Any ideas?
GWISA
Tue Nov 14, 2006 3:24 pm
How about specifying a different IP address on the 3rd interface and adding both IP's of your outgoing interfaces as gateways?
This should alternate connections between the two IP's
adaheem
Fri Feb 02, 2007 12:57 am
hi
will it be good if he uses cheap routers (nat boxes) to make differences in the gw & the subnet mask?
thanks
changeip
Sun Feb 04, 2007 8:32 pm
MT - Please add interface routing - please please please ... It would solve all these users problems with duplicate default gateways.
Sam
skynoc
Tue Feb 13, 2007 12:14 am
cannot make route with same subnet
regards
aitsecurity
Sat Feb 24, 2007 5:12 am
if a MK is a router
the interfaces is a broadcast domain, and you try put two interface in the same broadcast domain.
how make a rule for routes ? you can´t do this
best regards
Diagram:
Life
Did you try it?
Sat Mar 03, 2007 11:26 am
If I make:
IP addresses
192.168.0.1/24 - Local
10.5.8.1/24 - Local
195.10.10.200 - Public1
195.10.10.201 - Public2
Route
dst-address gateway interface mark
10.5.8.0/24 192.168.0.1 Local
0.0.0.0/0 195.10.10.200 Public1 p2p
0.0.0.0/0 195.10.10.201 Public2 other
0.0.0.0/0 195.10.10.1 Public1 (gateway of ISP)
Will it work?
aitsecurity
Re: Did you try it?
Sat Mar 03, 2007 3:34 pm
If I make:
IP addresses
10.5.8.1/24 - Local
Route
Will it work?
i am thinking , will not work
because you have in the same segment network in public1 and public2
the address scheme is wrong for a router.
if you can put example in public1 195.10.11.200 public1 and for the other 195.10.10.201 public2
and what mask you want use for the public interface ? 30 bits 255.255.255.252 ? or is a typical class C network 255.255.255.0 24 bits ?
best regards
Diganet
Sat Mar 03, 2007 4:40 pm
Try 3.0Beta6, is has Interface based routing.. so maybe 8)
/Henrik
Life
Fri Mar 09, 2007 4:07 pm
Thank you to all.
Users browsing this forum: Bing [Bot], iDaemon and 231 guests
