stucki
ETA v8
Sun Apr 16, 2017 5:14 pm
at the last mum someone said the next release will be v8 ; )
jarda
Re: ETA v8
Sun Apr 16, 2017 6:07 pm
The next release will be 7. 8 can come just after that. And 9 then... So what?
w0lt
Long time Member
Long time Member
Re: ETA v8
Sun Apr 16, 2017 7:15 pm
The release dates will be Q2/Q3 20xx, approximately. :lol:
Don't worry, it will be real soon now... :lol:
MTCNA - 2011
" The Bitterness of Poor Quality Remains Long After the Sweetness of Low Price is Forgotten "
normis
Re: ETA v8
Tue Apr 18, 2017 8:59 am
does the number really matter?
dtoffo
Trainer
Trainer
Re: ETA v8
Tue Apr 18, 2017 9:58 am
Right, the number doesn't matter...
the date could matter....
Davide
normis
Re: ETA v8
Tue Apr 18, 2017 10:02 am
I guess you are waiting for some specific feature, not the number or the date.
Murmaider
Re: ETA v8
Wed Apr 19, 2017 6:11 pm
multi-threaded bgp seems to be at the top of the list...
timberwolf
Re: ETA v8
Wed Apr 19, 2017 9:05 pm
Fix for muticore packet reordering comes to mind, if this isn't already silently fixed.
I didn't have the motivation of retesting this since a few months. Last time I stumbled upon this(6.34 I think) I disabled one core of the RB850Gx2 under test.
Im referring to viewtopic.php?t=102252 where someone tripped over this with IPTV and was put off to v7 and "maybe" ;-)
nz_monkey
Re: ETA v8
Thu Apr 20, 2017 1:56 pm
BGP != Forwarding. BGP is a routing protocol.
Multi-threaded BGP is hard, really hard. Juniper do not do it, Cisco IOS/IOS-XE do not do it. Processing the prefixes against all the filters, accross multiple cores and coming out with a result "in order" is very complex.
This is purely speculation, but it is more likely that Mikrotik will run BGP multi-threaded, with a thread per peer and/or per instance. This means processing of route updates for a peer would happen on a single core to maintain order, and that the post-processed routes would then be sent to another process that handles the RIB/FIB for that instance.
Outside of these improvement, there are likely to be big improvements in processing speed and the way the RIB's/FIB are stored in memory.
Mikrotik already discussed early results of the improvements that are coming, around 10x improvement in processing speed. See https://www.youtube.com/watch?v=ML0tr-9zTw0 at 2:57 mark..
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet NSE7 | Extreme Networks ENA
sguox
Trainer
Trainer
Re: ETA v8
Thu Apr 20, 2017 2:26 pm
number no longer relevant since free lifetime upgrade :)
roadracer96
Forum Veteran
Forum Veteran
Re: ETA v8
Fri Apr 28, 2017 3:38 am
Right. But they don't run bgp and ospf and fib updates and filtering and xxxxxxx under the same process. That's why a dual core major brand router can handle several hundred peers with convergence times 5x faster than 2 peers on a mikrotik.
parham
Re: ETA v8
Sun Apr 30, 2017 9:07 pm
No at all, as much as ROS and SWOS get more improvements and more features thats matter, just a suggestion its a time to add one important feature, let's encrypt, its now necessary for https, ikev2, sstp, ... hope see it in next RC release.
Thanks.
stucki
Re: ETA v8
Sat May 27, 2017 8:09 am
we should stop to annoy normis, I guess he hates openvpn and udp since to many poke for it.
cheeze
Re: ETA v8
Sat May 27, 2017 11:15 am
Juniper to my understanding now has multithreaded quite a bit starting with JUNOS 15. JUNOS 16 and past that are apparently introducing a multithreaded RPD as well. Now I do not know if the BGP portion within RPD is multithreaded but I was under the understanding that on JUNOS 17 that it's basically going to be a complete out and about rewrite of the entire routing stack to be more scalable and threaded. Granted this is what I was told in behind closed doors from Juniper so....not sure of the time frames.
That being said, I agree completely with you that it's incredibly difficult and generally not really all that worth it to do it at a super in depth level. Intra-process multithreading is too much in most cases and the benefit is very small most of the time. Unless the work is embarrassingly parallel, it's generally not that worth it.
Here's a link giving an outline:
https://books.google.com/books?id=SVvnD ... gp&f=false
tetecko
Re: ETA v8
Tue Jun 06, 2017 10:00 pm
+1000
upower3
Re: ETA v8
Wed Jun 07, 2017 5:23 pm
Only bugs really matters. Finish and polish existing features - this will be the best way.
brotherdust
Re: ETA v8
Fri Jun 23, 2017 8:52 pm
Multi-threaded BGP might be hard, but it's necessary; and, here's the thing: it's already a solved problem. I'm using this in production: https://github.com/osrg/gobgp.
  • I've verified it's multi-threaded.
  • Takes about 1GB for full Internet BGP table
  • Has lots of kick-ass modern features
  • Built for SDN from the ground up
mrz
Re: ETA v8
Mon Jun 26, 2017 12:18 pm
1GB for just one BGP feed :shock: that's a lot.
nz_monkey
Re: ETA v8
Mon Jun 26, 2017 12:24 pm
I agree, that is a lot.
cheeze
Re: ETA v8
Fri Jul 07, 2017 6:29 pm
Just wait till you see some of the L3VPN/L2VPN NLRI on a service provider on a route reflector. It's far more than that.....
barkas
Re: RE: Re: ETA v8
Fri Jul 07, 2017 6:48 pm
Full table doesn't fit in 1GB anymore.
pqatsi
Re: ETA v8
Fri Jul 07, 2017 8:52 pm
+1 for GoBGP. How expensive is RAM today? I dont think it matter for a router that must handle full BGP tables.
Users browsing this forum: AndyGs, babelmonk, Bing [Bot], CZFan, DevTek, neitro, sindy and 166 guests
