NickM
Frequent PPPoE terminations
Mon Apr 24, 2017 6:48 am
I have a broadband connection that connects with PPPoE. The connection works most of the time, but will sometimes terminate, disconnect, initialise and reconnect in a loop for a short period.
I am using a RB750Gr3 with RouterOS v6.37.3.
/ interface pppoe-client print
 0  R name="pppoe1" max-mtu=auto max-mru=auto mrru=disabled interface=ether1
      user="xxxx" password="xxxx" profile=default keepalive-timeout=60
      service-name="internet" ac-name="" add-default-route=no dial-on-demand=no use-peer-dns=no
      allow=pap,chap,mschap1,mschap2
Example log:
(Not the whole log for this particular occurrence. This one lasted ~5 minutes)
mar/08 21:19:21 pppoe,ppp,info pppoe1: disconnected
mar/08 21:19:31 pppoe,ppp,info pppoe1: initializing...
mar/08 21:19:31 pppoe,ppp,info pppoe1: connecting...
mar/08 21:19:41 pppoe,ppp,info pppoe1: terminating... - disconnected
mar/08 21:19:41 pppoe,ppp,info pppoe1: disconnected
mar/08 21:19:51 pppoe,ppp,info pppoe1: initializing...
mar/08 21:19:51 pppoe,ppp,info pppoe1: connecting...
mar/08 21:20:01 pppoe,ppp,info pppoe1: terminating... - disconnected
mar/08 21:20:01 pppoe,ppp,info pppoe1: disconnected
mar/08 21:20:11 pppoe,ppp,info pppoe1: initializing...
mar/08 21:20:11 pppoe,ppp,info pppoe1: connecting...
mar/08 21:20:22 pppoe,ppp,info pppoe1: terminating... - disconnected
mar/08 21:20:22 pppoe,ppp,info pppoe1: disconnected
mar/08 21:20:32 pppoe,ppp,info pppoe1: initializing...
mar/08 21:20:32 pppoe,ppp,info pppoe1: connecting...
mar/08 21:20:33 pppoe,ppp,info pppoe1: authenticated
mar/08 21:20:33 pppoe,ppp,info pppoe1: connected
Please let me know if more information is required.
Thanks.
mlpaul
Re: Frequent PPPoE terminations
Mon Apr 24, 2017 6:06 pm
I'm having this same exact issue, where the log just fills with those errors. I believe the issue is on the service provider's end, (in your case, where ever you are trying to log into). Check the connectivity on the other end of the pppoe connection to see if that is occasionally losing internet connectivity.
biatche
Sun Jun 25, 2017 7:59 pm
im facing this issue also.
maheshv
Sun Jul 02, 2017 5:22 am
Having same issue as well. Can someone please confirm if issue was resolved by ISP? I have raised this with my ISP and my issue is currently under investigation. It would be great if someone can please confirm.
inteq
Sat Mar 02, 2019 12:33 am
This topic was the 1st result so posting here.
In the same boat with my RB1100AHx4 Dude using PPPoE.
Randomly, after a clean reboot or firmware upgrade, the PPPoE connection will loop forever.
The only fix is to reboot again or disable/enable the interface connecting to the GPON.
I have never experienced such problems with any prior routers in this location. Plenty Asus routers and X86 PFSense/IPFire machines.
I let it for 10 minutes last time it happened. No luck.
I had to disable ether1 and enable it back. Instant PPPoE connection.
[admin@RB1100AHx4] > /log print
mar/02 00:11:50 system,info router rebooted
mar/02 00:11:54 pppoe,ppp,info RDS: initializing...
mar/02 00:11:54 pppoe,ppp,info RDS: connecting...
mar/02 00:12:01 pppoe,ppp,info RDS: terminating...
mar/02 00:12:02 pppoe,ppp,info RDS: disconnected
mar/02 00:12:02 pppoe,ppp,info RDS: initializing...
mar/02 00:12:02 pppoe,ppp,info RDS: connecting...
mar/02 00:12:02 interface,info ether1 link up (speed 1G, full duplex)
mar/02 00:12:02 interface,info ether2 link up (speed 1G, full duplex)
mar/02 00:12:02 interface,info ether4 link up (speed 1G, full duplex)
mar/02 00:12:02 interface,info ether6 link up (speed 100M, full duplex)
mar/02 00:12:02 script,info Main connection DOWN. Enabling eth12
mar/02 00:12:02 system,info device changed
mar/02 00:12:10 interface,info ether12 link up (speed 1G, full duplex)
mar/02 00:12:11 pppoe,ppp,info RDS: terminating... - disconnected
mar/02 00:12:11 pppoe,ppp,info RDS: disconnected
mar/02 00:12:11 pppoe,ppp,info RDS: initializing...
mar/02 00:12:11 pppoe,ppp,info RDS: connecting...
mar/02 00:12:11 system,info device changed
mar/02 00:12:11 script,info Main connection DOWN. Enabling eth12
mar/02 00:12:47 pppoe,ppp,info RDS: terminating... - disconnected
mar/02 00:12:47 pppoe,ppp,info RDS: disconnected
mar/02 00:12:47 system,info device changed
mar/02 00:12:47 script,info Main connection DOWN. Enabling eth12
mar/02 00:12:47 pppoe,ppp,info RDS: initializing...
mar/02 00:12:47 pppoe,ppp,info RDS: connecting...
mar/02 00:12:57 pppoe,ppp,info RDS: terminating... - disconnected
mar/02 00:12:57 pppoe,ppp,info RDS: disconnected
mar/02 00:12:57 system,info device changed
mar/02 00:12:57 script,info Main connection DOWN. Enabling eth12
mar/02 00:12:58 pppoe,ppp,info RDS: initializing...
mar/02 00:12:58 pppoe,ppp,info RDS: connecting...
mar/02 00:13:08 pppoe,ppp,info RDS: terminating... - disconnected
mar/02 00:13:08 pppoe,ppp,info RDS: disconnected
mar/02 00:13:08 system,info device changed
mar/02 00:13:08 script,info Main connection DOWN. Enabling eth12
mar/02 00:13:10 pppoe,ppp,info RDS: initializing...
mar/02 00:13:10 pppoe,ppp,info RDS: connecting...
mar/02 00:13:20 pppoe,ppp,info RDS: terminating... - disconnected
mar/02 00:13:20 pppoe,ppp,info RDS: disconnected
mar/02 00:13:20 system,info device changed
mar/02 00:13:20 script,info Main connection DOWN. Enabling eth12
mar/02 00:13:23 pppoe,ppp,info RDS: initializing...
mar/02 00:13:23 pppoe,ppp,info RDS: connecting...
mar/02 00:13:33 pppoe,ppp,info RDS: terminating... - disconnected
mar/02 00:13:33 pppoe,ppp,info RDS: disconnected
mar/02 00:13:33 system,info device changed
mar/02 00:13:33 script,info Main connection DOWN. Enabling eth12
mar/02 00:13:40 pppoe,ppp,info RDS: initializing...
mar/02 00:13:40 pppoe,ppp,info RDS: connecting...
mar/02 00:13:50 pppoe,ppp,info RDS: terminating... - disconnected
mar/02 00:13:50 pppoe,ppp,info RDS: disconnected
mar/02 00:13:50 system,info device changed
mar/02 00:13:50 script,info Main connection DOWN. Enabling eth12
mar/02 00:14:00 pppoe,ppp,info RDS: initializing...
mar/02 00:14:00 pppoe,ppp,info RDS: connecting...
mar/02 00:14:06 interface,info ether4 link down
mar/02 00:14:10 pppoe,ppp,info RDS: terminating... - disconnected
mar/02 00:14:10 pppoe,ppp,info RDS: disconnected
mar/02 00:14:10 system,info device changed
mar/02 00:14:10 script,info Main connection DOWN. Enabling eth12
mar/02 00:14:20 pppoe,ppp,info RDS: initializing...
mar/02 00:14:20 pppoe,ppp,info RDS: connecting...
mar/02 00:14:26 interface,info ether4 link down
mar/02 00:14:30 pppoe,ppp,info RDS: terminating... - disconnected
mar/02 00:14:30 pppoe,ppp,info RDS: disconnected
mar/02 00:14:30 system,info device changed
mar/02 00:14:30 script,info Main connection DOWN. Enabling eth12
mar/02 00:14:40 pppoe,ppp,info RDS: initializing...
mar/02 00:14:40 pppoe,ppp,info RDS: connecting...
mar/02 00:14:50 pppoe,ppp,info RDS: terminating... - disconnected
mar/02 00:14:50 pppoe,ppp,info RDS: disconnected
mar/02 00:14:50 system,info device changed
mar/02 00:14:50 script,info Main connection DOWN. Enabling eth12
mar/02 00:15:00 pppoe,ppp,info RDS: initializing...
mar/02 00:15:00 pppoe,ppp,info RDS: connecting...
mar/02 00:15:10 pppoe,ppp,info RDS: terminating... - disconnected
mar/02 00:15:10 pppoe,ppp,info RDS: disconnected
mar/02 00:15:10 system,info device changed
mar/02 00:15:10 script,info Main connection DOWN. Enabling eth12
mar/02 00:15:20 pppoe,ppp,info RDS: initializing...
mar/02 00:15:20 pppoe,ppp,info RDS: connecting...
mar/02 00:15:30 pppoe,ppp,info RDS: terminating... - disconnected
mar/02 00:15:30 pppoe,ppp,info RDS: disconnected
mar/02 00:15:30 system,info device changed
mar/02 00:15:30 script,info Main connection DOWN. Enabling eth12
mar/02 00:15:40 pppoe,ppp,info RDS: initializing...
mar/02 00:15:40 pppoe,ppp,info RDS: connecting...
mar/02 00:15:50 pppoe,ppp,info RDS: terminating... - disconnected
mar/02 00:15:50 pppoe,ppp,info RDS: disconnected
mar/02 00:15:50 script,info Main connection DOWN. Enabling eth12
mar/02 00:15:50 system,info device changed
mar/02 00:16:00 pppoe,ppp,info RDS: initializing...
mar/02 00:16:00 pppoe,ppp,info RDS: connecting...
mar/02 00:16:10 pppoe,ppp,info RDS: terminating... - disconnected
mar/02 00:16:10 pppoe,ppp,info RDS: disconnected
mar/02 00:16:10 system,info device changed
mar/02 00:16:10 script,info Main connection DOWN. Enabling eth12
mar/02 00:16:20 pppoe,ppp,info RDS: initializing...
mar/02 00:16:20 pppoe,ppp,info RDS: connecting...
mar/02 00:16:30 pppoe,ppp,info RDS: terminating... - disconnected
mar/02 00:16:30 pppoe,ppp,info RDS: disconnected
mar/02 00:16:30 system,info device changed
mar/02 00:16:30 script,info Main connection DOWN. Enabling eth12
mar/02 00:16:40 pppoe,ppp,info RDS: initializing...
mar/02 00:16:40 pppoe,ppp,info RDS: connecting...
mar/02 00:16:50 pppoe,ppp,info RDS: terminating... - disconnected
mar/02 00:16:50 pppoe,ppp,info RDS: disconnected
mar/02 00:16:50 system,info device changed
mar/02 00:16:50 script,info Main connection DOWN. Enabling eth12
mar/02 00:17:00 pppoe,ppp,info RDS: initializing...
mar/02 00:17:00 pppoe,ppp,info RDS: connecting...
mar/02 00:17:10 pppoe,ppp,info RDS: terminating... - disconnected
mar/02 00:17:10 pppoe,ppp,info RDS: disconnected
mar/02 00:17:10 system,info device changed
mar/02 00:17:10 script,info Main connection DOWN. Enabling eth12
mar/02 00:17:20 pppoe,ppp,info RDS: initializing...
mar/02 00:17:20 pppoe,ppp,info RDS: connecting...
mar/02 00:17:30 pppoe,ppp,info RDS: terminating... - disconnected
mar/02 00:17:30 pppoe,ppp,info RDS: disconnected
mar/02 00:17:30 script,info Main connection DOWN. Enabling eth12
mar/02 00:17:30 system,info device changed
mar/02 00:17:40 pppoe,ppp,info RDS: initializing...
mar/02 00:17:40 pppoe,ppp,info RDS: connecting...
mar/02 00:17:50 pppoe,ppp,info RDS: terminating... - disconnected
mar/02 00:17:50 pppoe,ppp,info RDS: disconnected
mar/02 00:17:50 script,info Main connection DOWN. Enabling eth12
mar/02 00:17:50 system,info device changed
mar/02 00:18:00 pppoe,ppp,info RDS: initializing...
mar/02 00:18:00 pppoe,ppp,info RDS: connecting...
mar/02 00:18:10 pppoe,ppp,info RDS: terminating... - disconnected
mar/02 00:18:10 pppoe,ppp,info RDS: disconnected
mar/02 00:18:10 script,info Main connection DOWN. Enabling eth12
mar/02 00:18:10 system,info device changed
mar/02 00:18:20 pppoe,ppp,info RDS: initializing...
mar/02 00:18:20 pppoe,ppp,info RDS: connecting...
mar/02 00:18:31 pppoe,ppp,info RDS: terminating... - disconnected
mar/02 00:18:31 pppoe,ppp,info RDS: disconnected
mar/02 00:18:31 script,info Main connection DOWN. Enabling eth12
mar/02 00:18:31 system,info device changed
mar/02 00:18:41 pppoe,ppp,info RDS: initializing...
mar/02 00:18:41 pppoe,ppp,info RDS: connecting...
mar/02 00:18:51 pppoe,ppp,info RDS: terminating... - disconnected
mar/02 00:18:51 pppoe,ppp,info RDS: disconnected
mar/02 00:18:51 system,info device changed
mar/02 00:18:51 script,info Main connection DOWN. Enabling eth12
mar/02 00:19:01 pppoe,ppp,info RDS: initializing...
mar/02 00:19:01 pppoe,ppp,info RDS: connecting...
mar/02 00:19:11 pppoe,ppp,info RDS: terminating... - disconnected
mar/02 00:19:11 pppoe,ppp,info RDS: disconnected
mar/02 00:19:11 system,info device changed
mar/02 00:19:11 script,info Main connection DOWN. Enabling eth12
mar/02 00:19:21 pppoe,ppp,info RDS: initializing...
mar/02 00:19:21 pppoe,ppp,info RDS: connecting...
mar/02 00:19:31 pppoe,ppp,info RDS: terminating... - disconnected
mar/02 00:19:31 pppoe,ppp,info RDS: disconnected
mar/02 00:19:31 system,info device changed
mar/02 00:19:31 script,info Main connection DOWN. Enabling eth12
mar/02 00:19:34 pppoe,ppp,info RDS: initializing...
mar/02 00:19:34 pppoe,ppp,info RDS: connecting...
mar/02 00:19:34 system,info device changed by admin
mar/02 00:19:44 pppoe,ppp,info RDS: terminating... - disconnected
mar/02 00:19:44 pppoe,ppp,info RDS: disconnected
mar/02 00:19:44 pppoe,ppp,info RDS: initializing...
mar/02 00:19:44 pppoe,ppp,info RDS: connecting...
mar/02 00:19:44 system,info device changed
mar/02 00:19:44 script,info Main connection DOWN. Enabling eth12
mar/02 00:19:54 pppoe,ppp,info RDS: terminating... - disconnected
mar/02 00:19:54 pppoe,ppp,info RDS: disconnected
mar/02 00:19:54 system,info device changed
mar/02 00:19:54 script,info Main connection DOWN. Enabling eth12
mar/02 00:19:54 pppoe,ppp,info RDS: initializing...
mar/02 00:19:54 pppoe,ppp,info RDS: connecting...
mar/02 00:20:04 pppoe,ppp,info RDS: terminating... - disconnected
mar/02 00:20:04 pppoe,ppp,info RDS: disconnected
mar/02 00:20:04 system,info device changed
mar/02 00:20:04 script,info Main connection DOWN. Enabling eth12
mar/02 00:20:05 pppoe,ppp,info RDS: initializing...
mar/02 00:20:05 pppoe,ppp,info RDS: connecting...
mar/02 00:20:14 system,info ppp profile <RDS> changed by admin
mar/02 00:20:15 pppoe,ppp,info RDS: terminating... - disconnected
mar/02 00:20:15 pppoe,ppp,info RDS: disconnected
mar/02 00:20:15 system,info device changed
mar/02 00:20:15 script,info Main connection DOWN. Enabling eth12
mar/02 00:20:16 pppoe,ppp,info RDS: initializing...
mar/02 00:20:16 pppoe,ppp,info RDS: connecting...
mar/02 00:20:26 pppoe,ppp,info RDS: terminating... - disconnected
mar/02 00:20:26 pppoe,ppp,info RDS: disconnected
mar/02 00:20:26 system,info device changed
mar/02 00:20:26 script,info Main connection DOWN. Enabling eth12
mar/02 00:20:29 pppoe,ppp,info RDS: initializing...
mar/02 00:20:29 pppoe,ppp,info RDS: connecting...
mar/02 00:20:40 pppoe,ppp,info RDS: terminating... - disconnected
mar/02 00:20:40 pppoe,ppp,info RDS: disconnected
mar/02 00:20:40 system,info device changed
mar/02 00:20:40 script,info Main connection DOWN. Enabling eth12
mar/02 00:20:46 pppoe,ppp,info RDS: initializing...
mar/02 00:20:46 pppoe,ppp,info RDS: connecting...
mar/02 00:20:56 pppoe,ppp,info RDS: terminating... - disconnected
mar/02 00:20:56 pppoe,ppp,info RDS: disconnected
mar/02 00:20:56 system,info device changed
mar/02 00:20:56 script,info Main connection DOWN. Enabling eth12
mar/02 00:21:06 pppoe,ppp,info RDS: initializing...
mar/02 00:21:06 pppoe,ppp,info RDS: connecting...
mar/02 00:21:17 pppoe,ppp,info RDS: terminating... - disconnected
mar/02 00:21:17 pppoe,ppp,info RDS: disconnected
mar/02 00:21:17 system,info device changed
mar/02 00:21:17 script,info Main connection DOWN. Enabling eth12
mar/02 00:21:27 pppoe,ppp,info RDS: initializing...
mar/02 00:21:27 pppoe,ppp,info RDS: connecting...
mar/02 00:21:37 pppoe,ppp,info RDS: terminating... - disconnected
mar/02 00:21:37 pppoe,ppp,info RDS: disconnected
mar/02 00:21:37 system,info device changed
mar/02 00:21:37 script,info Main connection DOWN. Enabling eth12
mar/02 00:21:47 pppoe,ppp,info RDS: initializing...
mar/02 00:21:47 pppoe,ppp,info RDS: connecting...
mar/02 00:21:57 pppoe,ppp,info RDS: terminating... - disconnected
mar/02 00:21:57 pppoe,ppp,info RDS: disconnected
mar/02 00:21:57 system,info device changed
mar/02 00:21:57 script,info Main connection DOWN. Enabling eth12
mar/02 00:22:07 pppoe,ppp,info RDS: initializing...
mar/02 00:22:07 pppoe,ppp,info RDS: connecting...
mar/02 00:22:17 pppoe,ppp,info RDS: terminating... - disconnected
mar/02 00:22:17 pppoe,ppp,info RDS: disconnected
mar/02 00:22:17 system,info device changed
mar/02 00:22:17 script,info Main connection DOWN. Enabling eth12
mar/02 00:22:27 pppoe,ppp,info RDS: initializing...
mar/02 00:22:27 pppoe,ppp,info RDS: connecting...
mar/02 00:22:37 pppoe,ppp,info RDS: terminating... - disconnected
mar/02 00:22:37 pppoe,ppp,info RDS: disconnected
mar/02 00:22:37 system,info device changed
mar/02 00:22:37 script,info Main connection DOWN. Enabling eth12
mar/02 00:22:47 pppoe,ppp,info RDS: initializing...
mar/02 00:22:47 pppoe,ppp,info RDS: connecting...
mar/02 00:22:50 interface,info ether1 link down
mar/02 00:22:50 system,info device changed by admin
mar/02 00:22:50 pppoe,ppp,info RDS: terminating...
mar/02 00:22:50 pppoe,ppp,info RDS: disconnected
mar/02 00:22:50 pppoe,ppp,info RDS: initializing...
mar/02 00:22:50 pppoe,ppp,info RDS: connecting...
mar/02 00:22:50 script,info Main connection DOWN. Enabling eth12
mar/02 00:22:51 system,info device changed by admin
mar/02 00:22:51 pppoe,ppp,info RDS: terminating...
mar/02 00:22:51 pppoe,ppp,info RDS: disconnected
mar/02 00:22:51 pppoe,ppp,info RDS: initializing...
mar/02 00:22:51 pppoe,ppp,info RDS: connecting...
mar/02 00:22:51 script,info Main connection DOWN. Enabling eth12
mar/02 00:22:56 interface,info ether1 link up (speed 1G, full duplex)
mar/02 00:22:57 pppoe,ppp,info RDS: authenticated
mar/02 00:22:57 pppoe,ppp,info RDS: connected
mar/02 00:22:57 script,info Main connection UP. Disabling eth12
mar/02 00:22:57 system,info device changed
mar/02 00:22:57 interface,info ether12 link down
BRMateus2
Sat Mar 02, 2019 2:29 am
Send supout to support@mikrotik.com, this is a bug they might don't have any to support output.
IYARINDRA
Wed Mar 06, 2019 10:59 am
I had the same issues last night for a period of time. My guess was my provider. By I seeing many people here having the same isuues. My curiosity filled.
I am using RB4011iGS+...
justdude
Wed Mar 06, 2019 3:11 pm
Also using pppoe to connect to isp. Also have dropouts. BUT they occur when I saturate uplink with uploads, keepalive in isp router keep timeouting and it auto disconnects. Do rest of you have traffic when it occurs (upload especially) or link is idle and it still happens?
inteq
Mon May 06, 2019 1:37 am
I only see it after a reboot/firmware update.
It is also very random. One reboot it could work, the next one might not.
Thus, I wrote a small script to disable the physical port (ether1 in my case) when the pppoe client has the status "disconnected" and enable it back after several seconds.
It fixes the problem for me, but it is an ugly hack.
Sent the supout, but considering this problem is from at least 2010, slim chances that MIkrotik will ever fix it.
matd
Wed May 08, 2019 7:02 pm
@NickM - you should try debug ppp/pppoe to see reason for disconnects. Also packet capture from your WAN interface could help.
ciberica
Sun May 12, 2019 7:37 am
Hello, has someone solved it or do you know why this happens?
sindy
Sun May 12, 2019 2:06 pm
Only logging and packet sniffing can help here. Until someone does that, and proves that way that it is a Mikrotik bug by showing that either PPPoE frames are not actually leaving the device although the log says they do or that correctly populated frames from the ISP's PPPoE server are received but do not lead to successful connection establishment, and sends a supout.rif file to support@mikrotik.com, there will be no solution to the issue. Bothering support without the evidence as above is pointless as there are things which may happen in the wild but the fantasy of the developers is insufficient to anticipate them, so they need to learn what actually happens to be able to improve the software to handle it.
Instead of writing novels, post /export hide-sensitive. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
Users browsing this forum: eworm, yakutpura and 85 guests
