imlenkon
Local DNS
Sat May 06, 2017 11:04 am
My local LAN is 192.168.2.1/24, My web server ip is 1921.68.2.250 but i want to now access all of my user visit my web server as a domain (imlenkon.com). like they enter browser imlenkon.com its go to 192.168.2.250.
Abdul Kader Linkon
Network Engineer
CIS, MCSE, CWNA,CEH
Mikrotik Consultant
MUM Presenter
MTCRE, MTCNA
https://www.facebook.com/groups/mikrotikexperts/
Pea
Re: Local DNS
Sat May 06, 2017 11:33 am
Do you have your domain DNS/DDNS name registered with your WAN IP address?
If yes, then you can do it with NAT.
These 3 lines will make your web server accessible from internet and also from LAN by your domain name:
add action=accept chain=forward comment="Accept dstnat pinholes" connection-nat-state=dstnat
add action=dst-nat chain=dstnat comment="WAN to web server" dst-address-type=local dst-port=80,443 protocol=tcp to-addresses=192.168.2.250
add action=masquerade chain=srcnat comment="LAN to web server" dst-address=192.168.2.250 protocol=tcp src-address=192.168.2.1/24
Edit: Thank you Sob, dst-port corrected
Sob
Re: Local DNS
Sat May 06, 2017 9:29 pm
If it's just web server, it's good idea to have dstnat rule with dst-port=80,443, otherwise all ports will go there.
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply. Not intended as incentive for masochists.
imlenkon
Re: Local DNS
Sun May 07, 2017 12:04 pm
[quote="Pea"]Do you have your domain DNS/DDNS name registered with your WAN IP address?
Thnx for your Reply,
I don't need to access from internet, i need only from my Local network IP to Domain name Like 192.168.2.250 convert to imlenkon.com, then user just enter their browser imlenkon.com then access 192.168.2.250 how is it possible???
Abdul Kader Linkon
Network Engineer
CIS, MCSE, CWNA,CEH
Mikrotik Consultant
MUM Presenter
MTCRE, MTCNA
Sob
Re: Local DNS
Sun May 07, 2017 3:13 pm
If users have router as DNS resolver, you can do:
/ip dns static
add address=192.168.2.250 name=imlenkon.com
imlenkon
Re: Local DNS
Wed May 10, 2017 7:54 pm
I try this but not working
Abdul Kader Linkon
Network Engineer
CIS, MCSE, CWNA,CEH
Mikrotik Consultant
MUM Presenter
MTCRE, MTCNA
cutedrummerboy
Re: Local DNS
Wed May 10, 2017 8:15 pm
after that you have to enable allow remote request in /ip dns and use your router ip address as your dns server ip in your pc.
Device: RB2011UIAS-RM, RB750GL, CISCO SG300-28, UNIFI UAP-LR
Users browsing this forum: dave864, Kindis, Quasar, Zacharias and 87 guests
