David1234
V6.39.1 - Unable to "Disable" nothing
Wed May 17, 2017 1:36 pm
when I press the red X on everywhere id doesn't disabe the interface\rule or what ever
also when I press "D"
it only disable when I write it in the cli
why is it?
normis
Re: V6.39.1 - Unable to "Disable" nothing
Wed May 17, 2017 3:32 pm
There is definitely too little information in your post to provide any kind of answer :)
Are you logged in with a user that has the FULL Group? Are you connected via MAC address or IP address? Have you checked the LOG ?
SiB
Wed May 17, 2017 3:42 pm
Try in fresh open WinBox > Tools > Clear Cache and WinBox should be a 3.11
MTCNA + MTCRE + MTCINE | ~600 users at ~150 RouterBoards in EMEA | Telegram: @SiB_PL | WebChat: Tokonda
WinBox Tip: F6 works as ALT+TAB
David1234
Thu May 18, 2017 6:59 pm
I'm connected as admin , group FULL ,try to enter MAC and also IP
doesn't see anything in the log - didn't say "disable\enable"
I have restart the router so all I have is: ether1 + wlan1
no other setting
jarda
Thu May 18, 2017 8:38 pm
Reset without defaults and make all settings you need from scratch.
strods
Fri May 19, 2017 9:10 am
David1234 - Most likely you are using Winbox 2. If that is correct, then upgrade to Winbox 3.11 in order to make it work.
David1234
Sun May 21, 2017 9:52 am
OK
yes I'm using the old version - I will replace it
Thanks ,
Users browsing this forum: sashoatanasow and 94 guests
