mushmx
Enable multicast to print with Airprint
Thu May 18, 2017 6:27 am
Hi
I want to print vía Airprint and I was searching in google and I found that Airprint need Multicast. Actually I loaded the multicast package and enable PIM but I can't print from my Ipad.
Does anybody know, what else I need to configure to permit the multicast on the interface bridge?
doneware
Trainer
Trainer
Re: Enable multicast to print with Airprint
Thu May 18, 2017 10:03 am
you don't need nothing. bridge will forward (flood) multicast frames. airprint uses bonjour (mdns) for service discovery only. but you need default forward=on on your wireless to enable c2c communication
#TR0359
doneware
Trainer
Trainer
Thu May 18, 2017 10:05 am
and one more thing: mdns cannot be routed, works only inside a broadcast domain
#TR0359
idlemind
Sat Jun 24, 2017 7:32 pm
You can setup DNS based service discovery. I'm not sure if the built-in caching resolver supports this. It works with BIND and MS DNS and is a valid design for AirPrint in a routed network.
beef
Sun Jun 24, 2018 4:12 am
FWIW, this also solved my Apple HomePod problem where there was no "Now Playing" card in the control center.
Users browsing this forum: kiwitech, meazz1, MSN [Bot], samwarez and 216 guests
