MUM Europe 2020
tega2rule
python telnetlib not working on Mikrotik routerOs
Mon Jun 05, 2017 11:36 am
please can some help me out here, the below Python script was suppose to log in to my mikrotik router 750 ver6.30.2 and disable interface 4, but it is working. i have tried several modifications, but cant get it to work. from the router log, the sript is able to log in, but its unable to carryout the configuration change
import getpass
import telnetlib
import time
HOST = "192.168.1.5"
user = input("Enter your remote account: ")
password = getpass.getpass()
tn = telnetlib.Telnet(HOST)
tn.read_until(b"Login: ")
tn.write(user.encode('ascii') + b"\n")
time.sleep(1)
#tn.write(b"\n")
if password:
    tn.read_until(b"Password: ")
    tn.write(password.encode('ascii') +  b"\n")
time.sleep(1)
tn.read_until(b"] > ")
print ("[OK] Login successful")
time.sleep(1)
tn.write(b" /interface disable 4"+ b"\n")
print(tn.read_all().decode('ascii'))
idlemind
Re: python telnetlib not working on Mikrotik routerOs
Mon Jun 26, 2017 5:33 pm
You should consider at least SSH and key based authentication or the MikroTik API to make your changes.
TELNET passes everything in clear text, including that password of yours.
Side-note: I wasn't able to get the telnet package from PIP to install on my machine (Python3) to test. I'm not sure if it is compatible.
che
Mon Jun 26, 2017 8:06 pm
Agreed with idlemind, avoid telnet like a plague. But in case you are doing it just on a local device, here is something you can tinker with to fix that script assuming login works like you stated:
mtcommand = "/interface disable 4"
prompt = ">"
tn.read_until(prompt)
time.sleep(4)
tn.write(mtcommand.encode("UTF-8")+"\r\n")
Use "paramiko" library and create ssh connection if you want to write a Python script for production.
mrz
Tue Jun 27, 2017 10:27 am
You forgot that RouterOS terminal by default will output pretty lines with colour codes. Either you take this into account or turn off colours and/or enable dumb mode.
See the manual for console login options
https://wiki.mikrotik.com/wiki/Manual:C ... in_options
savage
Tue Jun 27, 2017 9:04 pm
There's nothing pretty about it. It's a HUGE PITA :evil: Even with +cti, it's still not a "dumb" terminal.
Regards,
Chris
mrz
Wed Jun 28, 2017 3:28 pm
I am sorry to hear that it feels ugly for you, unfortunately we cannot choose colours to fit everyone's taste. We are open to suggestions, so if you have something in mind, feel free to suggest what other colour scheme to use.
savage
Wed Jun 28, 2017 3:34 pm
I'm sorry you feel I'm complaining about "colors."
Drop the ANSI completely from the terminal. Like any other sane network vendor.
Regards,
Chris
idlemind
Thu Jun 29, 2017 6:56 am
Not to derail the thread anymore but I actually really like the ANSI coloring. It feels way more readable than the "other" vendors.
Users browsing this forum: eworm, Google Feedfetcher, inteq, macsrwe, MSN [Bot], oskarsk, smarttruss and 101 guests
