CateFul
Copy packets and send to destination
Fri Jun 16, 2017 4:51 pm
Is it possible to copy a packet passing through Mikrotik and forward to another host for analysis? I mean the original packet still goes through to its intended host and its copy goes to another host. I know the packet sniffer can do that but it's in TZSP. The analysis software is custom, not WireShark.
Shadeofspirit
Re: Copy packets and send to destination
Fri Jun 16, 2017 5:26 pm
look information about calea package
MTCNA, MTCWE
idlemind
Fri Jun 16, 2017 7:47 pm
You can have the MikroTik send flow data, NetFlow and IPFIX are supported. Hopefully the analysis software support those formats. Alternatively nProbe can receive NetFlow / IPFIX data and you may be able to write a plugin to have it export data in the format needed by your custom tool. I don't think NetFlow supports sending the whole packet if you need to look inside the encapsulated data though. It's useful for metric based information like how many packets of a particular protocol you're sending and between which parties.
What you're probably really after is port-mirroring. Aka Cisco SPAN. This will let you send all data for say an Ethernet port out another Ethernet port for collection.
CateFul
Sat Jun 17, 2017 3:15 am
Thanks everyone!
Calea did the trick, and since its firewall based I can even do some filtering before sending the packet for further analysis.
Users browsing this forum: No registered users and 81 guests
