MUM Europe 2020
Steveocee
Interface shows R (running) when it's not
Tue Jun 27, 2017 10:07 pm
Hello all,
Sorry to come to you with a problem but I'm stumped by this! Setup is an x86 installation (forced to 64bit). Ethernet setup is as below;
# jun/27/2017 19:22:02 by RouterOS 6.38.7
# software id = K6ZK-DBVU
set [ find default-name=ether1 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether2 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether3 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether4 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
However the interfaces always show as running even though they are not bridged or switched at all. 2 are the servers onboard and 2 are an additional Intel card. Only ether4 has a cable into it which is to my LAN which I'm using to access it (so I understand that should have an R).
[sc@MikroTik] > /interface print
 #     NAME                                TYPE       ACTUAL-MTU L2MTU  MAX-L2MTU MAC-ADDRESS
 0  R  ether1                              ether            1500                  90:E2:BA:0D:66:30
 1  R  ether2                              ether            1500                  90:E2:BA:0D:66:31
 2  R  ether3                              ether            1500                  D4:AE:52:B7:3E:10
 3  R  ether4                              ether            1500                  D4:AE:52:B7:3E:11
[sc@MikroTik] >
I'm running latest bugfix and have never come across this before. Anybody else found and fixed this?
Steve "Steveocee" Carter
PC Gamer, Airsofter, MikroTik Nerd
My Website - My MikroTik Tutorials
pukkita
Trainer
Trainer
Re: Interface shows R (running) when it's not
Wed Jun 28, 2017 12:27 pm
I would start looking into the BIOS and network card BIOS (if any) settings. Have you tried another ROS version?
Simplicity is the Ultimate Sophistication - Da Vinci
Getting the most out of this forum
Steveocee
Wed Jun 28, 2017 3:53 pm
Thank you for your reply.
It was an ancient 5.5 to start with, I moved it to 6.31 (and forced 64bit) then up to latest bugfix. As it turns out now I've decided against running it on the bare metal as I need to use the server for another purpose so have completely destroyed the install and have opted to go for ESXi and a CHR image.
mrz
Wed Jun 28, 2017 4:06 pm
x86 by default have disabled running check.
Set disable-running-check=no for Ethernet interfaces.
niamul
Wed Jun 28, 2017 7:43 pm
Where would we find this?
- waiting for that last laugh
Sob
Wed Jun 28, 2017 8:10 pm
In terminal:
/interface ethernet set disable-running-check=no <interface name>
I don't see it in WinBox/WebFig.
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply. Not intended as incentive for masochists.
mrz
Thu Jun 29, 2017 10:35 am
Yes, this option is available only from terminal.
nishadul
Mon Oct 22, 2018 6:22 am
In terminal:
it is important for me
terintamel
Thu Mar 07, 2019 3:53 pm
I have used this command for x86 ROS fine before. However I an setting up a CHR instance in ESXI and this command does not do anything.
How do you get this to work on a CHR?
Steveocee
Thu Mar 07, 2019 4:49 pm
You won't.
The interface on your CHR will always be connected to the vSwitch/port group in ESXi.
Users browsing this forum: 0pl0pl, arielf, aysan, Bing [Bot], professional22 and 126 guests
