MUM Europe 2020
amilus
ikev2 win 13801 osx is work
Tue Jul 18, 2017 11:09 am
Hello
ikev2 eap-radius
OSX and iPhone is work
Windows7 error 13801
My Config
/ip ipsec mode-config
add address-pool=pool name=ikev2 split-include=0.0.0.0/0
/ip ipsec policy group
add name=ikev2
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-128-cbc,3des lifetime=8h pfs-group=\
none
add enc-algorithms=aes-128-cbc,3des lifetime=8h name=ipsec pfs-group=none
add auth-algorithms=sha256 enc-algorithms="" lifetime=8h name=ikev2 pfs-group=\
none
/ip ipsec peer
add address=0.0.0.0/0 auth-method=eap-radius certificate= Wildcard.crt \
enc-algorithm=aes-256 exchange-mode=ike2 generate-policy=port-strict \
hash-algorithm=sha256 mode-config=ikev2 passive=yes policy-template-group=\
ikev2
/ip ipsec policy
add dst-address=0.0.0.0/0 group=ikev2 src-address=0.0.0.0/0 template=yes
/ip ipsec user settings
set xauth-use-radius=yes
Win connect log
03:08:10 echo: ipsec payload seen: TS_R
03:08:10 echo: ipsec ike auth: respond
03:08:10 echo: ipsec processing payload: ID_I
03:08:10 echo: ipsec peer ID (ADDR4): 192.168.88.23
03:08:10 echo: ipsec processing payloads: NOTIFY
03:08:10 echo: ipsec notify: MOBIKE_SUPPORTED
03:08:10 echo: ipsec my ID (ADDR): 45.32.227.242
03:08:10 echo: ipsec adding payload: ID_R
03:08:10 echo: ipsec adding payload: CERT
03:08:10 echo: ipsec processing payload: NONCE
03:08:10 echo: ipsec adding payload: AUTH
03:08:10 echo: ipsec adding payload: EAP
mrz
Re: ikev2 win 13801 osx is work
Tue Jul 18, 2017 12:07 pm
amilus
Tue Jul 18, 2017 8:09 pm
I am a wildcard certificate in strongswan no problem
Simply place the intermediate certificate in /etc/ipsec.d/cacerts
Certificate status in routeros
Users browsing this forum: MSN [Bot] and 55 guests
