MUM Europe 2020
triac
UDP problems through EoIP tunnel
Mon Nov 27, 2006 6:28 pm
Hi, this is my problem...
I have two remote Lan's connected with wireless bridge using tree MT routers and double EoIP configuration.
this is the configuration:
MT1:
eth 1 IP: 192.168.0.10
wlan1 IP: 10.0.0.1
EoIP tunnel 1: remote IP: 10.0.0.2 - Tunnel ID: 1
Bridge 1: ports= eth1, EoIP tunnel 1
MT2:
eth 1 IP: 192.168.0.200
wlan 1 IP: 10.0.0.2
wlan 2 IP: 10.1.1.1
EoIP tunnel 1: remote IP: 10.0.0.1 - Tunnel ID:1
EoIP tunnel 2: remote IP: 10.1.1.2 - Tunnel ID:2
Bridge 1: ports= eth1, EoIP 1, EoIP 2
MT3:
eth 1 IP: 192.168.0.11
wlan1 IP: 10.1.1.2
EoIP tunnel 1: remote IP: 10.1.1.1 - Tunnel ID: 2
The network from Computer 1 and Computer 2 work fine but I have problems with UDP ports.
Some test result using bandwidth test:
TCP from PC 1 to PC 2 OK (both directions) (about 8/10 Mbps)
TCP from PC 2 to PC 1 OK (both directions) (about 8/10 Mbps)
UDP from PC 1 to PC 2 and from PC 2 to PC 1 FAIL (0 bps).
If I repeat test using Btest utility in winbox from MT1 to MT3 all work fine!!!
From MT 1 to PC 2 FAIL!
From MT 3 to PC 1 FAIL!
I'm becoming crazy with this problem! I need to work with UDP 3001 port.
Suggestions?
Thank You
Paolo
JJCinAZ
Tue Nov 28, 2006 4:21 pm
Are there firewalls on the pc's?
triac
Tue Nov 28, 2006 11:22 pm
Eh, no.... All firewall are disabled...
Paolo Torri
wirdo
Tue Nov 28, 2006 11:26 pm
1. try using different MAC addresses on each tunnel.
2. mt2 wlan interfaces in ap-bridge mode grouped in bridge together with ether, then eoip tunnel between 1 and 3.
garriad
Re: UDP problems through EoIP tunnel
Sat Dec 02, 2017 12:15 pm
i have the same problem
try to increase MTU
sry for my english )
Users browsing this forum: lostdummy and 51 guests
