grims
Mikrotik hEX lite (RB750r2) and satellite updates
Wed Aug 02, 2017 4:51 pm
Hi!
Mikrotik hEX lite (RB750r2, It is now installed at 6.35.4) an error is returned when updating packages through the satellite "ERROR: connection timed out".
RTT = ~700 ms, can this affect updates?
[admin@MikroTik] > ping upgrade.mikrotik.com
SEQ HOST SIZE TTL TIME STATUS
0 8.8.8.8 56 49 564ms
1 8.8.8.8 56 49 599ms
2 8.8.8.8 56 49 590ms
3 8.8.8.8 56 49 586ms
sent=4 received=4 packet-loss=0% min-rtt=564ms avg-rtt=584ms max-rtt=599ms
[admin@MikroTik] > ping update.mikrotik.com
0 8.8.8.8 56 49 591ms
1 8.8.8.8 56 49 610ms
2 8.8.8.8 56 49 603ms
3 8.8.8.8 56 49 592ms
sent=4 received=4 packet-loss=0% min-rtt=591ms avg-rtt=599ms max-rtt=610ms
grims
Re: Mikrotik hEX lite (RB750r2) and satellite updates
Fri Feb 19, 2021 4:51 pm
No RTT 700+ does not affect. Check DNS resolution.
sindy
Sun Feb 21, 2021 11:19 am
For me both fqdns resolve properly, so check your own DNS setup. 8.8.8.8 is an IP of Google DNS server, so something is really wrong in your DNS chain.
You may resolve the fqdns to IPs somewhere else and then create static DNS items in the configuration of the device you're trying to upgrade.
[me@myTik] > put [resolve update.mikrotik.com]
159.148.147.205
[me@myTik] > put [resolve upgrade.mikrotik.com]
159.148.172.226
Also, upgrading from 6.35.4 directly to current long-term (6.47.9 as of writing this) is a voucher for a headache. So if the device is still running 6.35.4., I'd start from upgrading to the last 6.40.x release, then to the last 6.41x one, and then further, but I'm still not sure whether a jump to 6.47.9 will be safe. The level of risk depends on the configuration - some parts of it haven't changed at all, some (e.g. IPsec) have seriously. So you may want to post the export for a check; definitely make an export and download it somewhere else before the upgrade, so that you could eventually reconstruct the configuration if the upgrade fails.
Instead of writing novels, post /export hide-sensitive. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
Users browsing this forum: ak4020, nickrod50 and 179 guests
