Hellbound
Long time Member
Long time Member
Station mode does not work, "SEARCHING FOR NETWORK"
Tue Oct 26, 2004 11:28 am
Hi guys
I have installed routeros only since 3 days ago.
I am using Atheros 5212 PCI and Via and Dlink ethernet AMD 1600 CPU ASUS motherboard, I have here 2 AP, one is senao and other is InterEpoch but i cannot make it connect to AP in station mode, have set the SSID/Band/Frequency antenna and etc all properly, and even APs show up in Scan window but when I connect to them it only says "SEARCHING FOR NETWORK".
Note: system working fine in hotspot and can do client authenticating and all stuff.
Roman
Tue Oct 26, 2004 12:12 pm
What does the `/l p w` command say? Is an interface connecting and disconnecting or just not connecting?
Hellbound
Long time Member
Long time Member
Tue Oct 26, 2004 5:20 pm
thans for prompt reply
it seems it is connectecing only for less than a second and its keep going like that
normis
Wed Oct 27, 2004 3:30 pm
if you are using the 2.8.18 then there are no problems with it as far as we know. maybe make a supout.rif file and send to support
mip
Wed Oct 27, 2004 9:41 pm
ap side mac filter usuali does the same
https://www.youtube.com/watch?v=j7q0Y_JZMrg - the country you must visit
Users browsing this forum: evghoul and 128 guests
