happycanadian
Unable to paste byte 0
Sat Aug 19, 2017 12:04 am
I am unable to successfully paste .rsc file from my desktop to the router. I get 0 bytes... I also am having issues copying the config file in terminal and can only copy/paste a couple of lines at a time. If I try to do a full page I get booted out of the router.
libyatik
Re: Unable to paste byte 0
Sat Aug 19, 2017 4:59 am
update winbox - device - and retest
happycanadian
Sun Aug 20, 2017 8:53 pm
I did download the latest version and retested and it still doesn't work.
BartoszP
Mon Aug 21, 2017 4:36 am
Try to disable antivirus.
Are you connected with IP or MAC? IP is far, far more stable for transfering files.
Real admins use real keyboards.
happycanadian
Wed Aug 23, 2017 7:45 pm
Even with disabling the antivirus I still have the same issue... I am using Windows..
k6ccc
Wed Aug 23, 2017 8:25 pm
You say you are pasting from your computer to the router. Tell us exactly what steps you are doing.
Sent from my phone using Tapatalk, so blame any typos on Android!
RB750Gr3, RB750r2, CRS326-24G-2S (in SwitchOS), CSS326-24G-2S, CSS106-5G-1S, RB260GS
Not sure if I beat them in submission, or they beat me into submission
Jim
happycanadian
Wed Aug 23, 2017 9:14 pm
I connect using winbox version 3.11 with a ethernet cable in port 3 of the Mikrotik RB201 with base config running version 6.23. When I copy from notepad I can only paste in a max of 10 lines into terminal. If I try to do more than 10 lines none of the config is applied and I get booted out of the router. I also have an issue copying files like jpeg and html. I get return of 0 bytes
Thanks for your support guys
libyatik
Thu Aug 24, 2017 2:15 am
upgrade routeros to latest and retest
Users browsing this forum: MSN [Bot] and 97 guests
