g22113
IPsec EC
Sat Aug 19, 2017 3:30 pm
Happy to see that there's finally support for ECDH groups in IPsec, but there seem to be compatibility issues with strongSwan (5.6.0):
charon[935]: 15[ENC] invalid DH public value size (65 bytes) for ECP_256
charon[935]: 09[ENC] invalid DH public value size (97 bytes) for ECP_384
charon[935]: 11[ENC] invalid DH public value size (133 bytes) for ECP_521
According to crypto/diffie_hellman.c, strongSwan expects one byte less (64, 96, or 132) than RouterOS is trying to send...
ziegenberg
Re: IPsec EC
Mon Aug 21, 2017 11:23 am
Hi!
Maybe you want to post your request as an answer to this post: viewtopic.php?f=21&t=123936&start=50#p613935. And you may send an email to support@mikrotik.com
greetings, Daniel
emils
Re: IPsec EC
Mon Aug 21, 2017 3:55 pm
Should be fixed in the next release candidate version (6.41rc17 or later). Please let us know if you experience any issues with this version.
g22113
Re: IPsec EC
Thu Aug 24, 2017 1:50 pm
Thanks, I tried rc17 and rc18, but:
13[ENC] invalid DH public value size (130 bytes) for ECP_521
13[IKE] remote host is behind NAT
13[IKE] applying DH public value failed
Meanwhile with ecp256 and ecp384:
10[LIB] MAC verification failed
10[ENC] verifying encrypted payload integrity failed
10[ENC] could not decrypt payloads
10[IKE] integrity check failed
10[IKE] IKE_AUTH request with message ID 1 processing failed
(I'm using IKEv2 PSK; so far only tried this with peer configuration, not phase2 proposals yet)
emils
Re: IPsec EC  [SOLVED]
Thu Aug 31, 2017 11:37 am
6.41rc21 will contain additional fixes regarding this issue. Please let us know if you experience any issues with this version.
Users browsing this forum: No registered users and 64 guests
