morheb
telnet on port 80
Sun Aug 20, 2017 12:06 pm
hello everyone
i am using cmd and i want to telnet on port 80
i am supposed to get reply when i connect but i dont get anything
i try to send get request like in the examples i saw but what ever i write i get " bad request error"
what should i do?
BartoszP
Re: telnet on port 80
Sun Aug 20, 2017 12:24 pm
Do you use Mikrotik router?
What is cmd? Isn't it Windows shell?
What examples you are trying?
If you write "whatever" why do you expect proper answer?
Real admins use real keyboards.
morheb
Sun Aug 20, 2017 12:51 pm
i use rb951
i saw this video https://www.youtube.com/watch?v=T3h-2YnrdKY
and other examples online using cmd to telnet on port 80
i tried to do the same with my mikrotik but i didnt get any reply
and if i try to send any request i get bad request error and connection closes
pe1chl
Sun Aug 20, 2017 1:30 pm
It is normal that you do not get any reply when you connect to a http server.
To understand that, study the http protocol in more detail. There is no initial welcome message like with FTP or SMTP.
When you send a request, it has to conform to the http protocol.
morheb
Tue Aug 22, 2017 8:41 am
thank you for your reply
now i understand
and is it the same with api? i got no reply either
and one more thing, if i connect to the port 80 with telnet, can i control the router and create users for hotspot?
thanks
pe1chl
Tue Aug 22, 2017 11:50 am
I would not advise managing the router from port 80 using telnet. Use port 23 for that.
Or better use SSH on port 22.
For API you need special software that talks according to that protocol.
normis
Tue Aug 22, 2017 2:11 pm
None of this makes any sense. Please explain what you are trying to do and why. Telnet to port 80 has nothing to do with MikroTik devices.
libyatik
Tue Aug 22, 2017 6:08 pm
you cant telnet from your host with port 80
you can use remote server to telnet through a browser embedded telnet client
k6ccc
Wed Aug 23, 2017 12:45 am
Or even better, SSH on a non-standard port with some other restrictions such as what IPs or interfaces can access, port knocking, VPN, etc. In additon to other security features, my routers use a non-standard port for SSH, FTP, HTTP and WinBox, but I have firewall rules that drop packets on the standard ports only so I can see how many attempts there are on those ports. On one of my routers, since the last time I reset the counters a week ago there have been 92 attempts on port 21, 760 attempts on port 22, and 3,304 attempts on port 23. Port 8291 for WinBox only had one however.
Unless there is a really good reason to allow any remote access (and there are some), don't allow any access to the router from the internet.
RB750Gr3, RB750r2, CRS326-24G-2S (in SwitchOS), CSS326-24G-2S, CSS106-5G-1S, RB260GS
Not sure if I beat them in submission, or they beat me into submission
Jim
acruhl
Wed Aug 23, 2017 7:07 am
Umm. You absolutely can telnet to port 80 to test connectivity. This is basic networking 101:
$ telnet 192.168.88.1 80
Trying 192.168.88.1...
Connected to 192.168.88.1.
Escape character is '^]'.
HEAD
HTTP/1.0 400 Bad Request
Connection: close
Content-Length: 113
Date: Wed, 23 Aug 2017 04:03:26 GMT
Expires: 0
<html>
<head><title>Error 400: Bad Request</title></head>
<body>
<h1>Error 400: Bad Request</h1>
</body>
</html>
Connection closed by foreign host.
Once we know what the original user is actually trying to do then someone can give a correct answer.
Stuff.
libyatik
Thu Aug 24, 2017 12:24 am
HEAD
Connection: close
Content-Length: 113
Expires: 0
<html>
<body>
</body>
</html>
connecting to http server will require text command post and get methods
protocols are independent from ports
you can use telnet tool to connect to any protocol but you cant use telnet commands
normis
Thu Aug 24, 2017 11:30 am
+1 about this
Users browsing this forum: No registered users and 19 guests
