MUM Europe 2020
rroca@guifi
Route filters works, but trespassing
Sun Dec 03, 2006 2:18 pm
Description:
4 routers, all connected in this way:
A <--> B <--> C <--> D
And having routing-test enabled on routers B and C (which are in the middle) and filtering all unwanted networks (distinct than 10.0.0.0/8-27) like this:
/ routing filter
add chain=ospf-out prefix=10.0.0.0/8 prefix-length=8-27 invert-match=no \
    action=accept comment="" disabled=no
add chain=ospf-out invert-match=no action=discard comment="" disabled=no
Routes distinct than 10.0.0.0/8 with prefix 28-32 doesn't appear on routers B and C, so looks like the filters are working OK, but....
Having a local route on router A like 192.168..0.0/24, which is correctly filtered on routers B and C, do appear again on router D. How it could be possible? Is there any way to avoid this? (there is no direct connection between router A and D, and what is wanted to achieve is avoid routes trespassing the filters)
Tested on 2.9.30 and 2.9.38
tneumann
Sun Dec 03, 2006 7:01 pm
Link state protocols such as OSPF can only filter which routes are actually installed into a routers local routing table, but they are by definition not allowed to exclude selected LSAs from their advertisements, as this would break the link state calculation on other routers. Therefore filtering routes on B and C does not prevent them from still appearing in the LSDB of router D and then being installed into the local routing table on D if you do not filter them there.
--Tom
Users browsing this forum: SeparateReality, sindy and 144 guests
