Borage
Realtek 8201
Wed Oct 27, 2004 3:02 am
I can't get Realtek 8201 LAN interfaces to work with MikroTik. In the routers PCI resources, it shows up as an NVIDIA nForce Ethernet Controller. I think the kernel module is nvnet and should be included in the 2.4 kernel, but I might be wrong about that.
cmit
Wed Oct 27, 2004 2:09 pm
The MikroTik device compatibility list (http://www.mikrotik.com/docs/ros/2.8/gu ... st.content) doesn't list the chip/card as supported - so I suppose there's no way to get it to work right now...
Just that there IS a linux driver (even in the standard distros/kernel) doesn't necessarily mean that it is supported in RouterOS. And you can't load "normal" linux device drivers in RouterOS...
Best regards,
Christian Meis
Borage
Wed Oct 27, 2004 2:56 pm
There is an option in the MikroTik driver settings were you can add and "copy-from" and I guess that you can upload a driver with ftp and then run this command.
Have anyone did that and where do you get the driver from?
normis
Wed Oct 27, 2004 2:59 pm
no, this is not possible in RouterOS.
Borage
Wed Oct 27, 2004 3:03 pm
Okey, I got this option when I press the TAB key, so I thought it was possible.
Eugene
Forum Veteran
Forum Veteran
Wed Oct 27, 2004 3:05 pm
These options are used for different purposes. See http://www.mikrotik.com/docs/ros/2.8/gu ... e.frameset
Borage
Wed Oct 27, 2004 3:10 pm
I usually use it to import the license key.
normis
Wed Oct 27, 2004 3:12 pm
copy-from is a generic command in all menus. in `driver` it doesn't have any real purpose.
Borage
Wed Oct 27, 2004 3:14 pm
You are really fast, I saw my mistake and you responded before I had a chance to correct it. :D
normis
how do you import the license key with copy-from ? license can be imported with
[normis@demo.mt.lv] > system license import file-name=
if from a file or simply by pasting it into telnet session.
Borage
Wed Oct 27, 2004 3:15 pm
Exactly, I upload the key by ftp and then run this command.
Users browsing this forum: eworm, joshfinlay and 56 guests
