wombat
Static route PPTP downtime
Wed Sep 13, 2017 1:33 pm
I have static route via PPTP and at every downtime/restart this route has cancel and is need manual make it.. :/ Any to create "static" route which resist these problems?
Thank you.
idlemind
Re: Static route PPTP downtime
Thu Sep 14, 2017 9:27 am
Are you targeting the static route to an interface? If you are you could try using the IP of the remote device directly and let the router determine which interface to use dynamically.
Alternatively, is it a route within a PPP profile or secret?
wombat
Thu Sep 14, 2017 10:04 am
/ip route print
 0 A S  0.0.0.0/0                                    1
 1 ADC  10.75.1.0/24       10.75.1.1       bridge1                   0
 2 ADC  10.75.2.0/24       10.75.2.1       bridge1                   0
 3 ADC  10.75.4.180/32     10.75.4.1       <pptp-j7>                 0
 4 ADC  10.75.4.181/32     10.75.4.1       <pptp-gabriel>            0
 5 ADC  10.75.10.0/24      10.75.10.1      bridge1                   0
 6 ADC  10.75.11.0/24      10.75.11.1      bridge1                   0
 7 ADC  10.75.12.0/24      10.75.12.1      bridge1                   0
 8 A S  10.75.17.0/24                      <pptp-j7>                 1
Line 8 after downtime is gateway <unkwnown> is need manully set again.
wombat
Tue Sep 19, 2017 11:22 pm
any idea? I still have to set up a route manually several times a day :-(
idlemind
Wed Sep 20, 2017 12:25 am
Post a /ppp export
wombat
Wed Sep 20, 2017 2:13 pm
Server
/ppp profile
set *0 change-tcp-mss=default dns-server=10.75.5.1 use-encryption=required
set *FFFFFFFE change-tcp-mss=default local-address=10.75.4.1 remote-address=vpn \
    use-upnp=yes
Client
/ppp profile
set *0 change-tcp-mss=default use-encryption=required
set *FFFFFFFE local-address=10.75.17.1 remote-address=dhcp
idlemind
Wed Sep 20, 2017 2:58 pm
Something isn't right with the *0 and *FFF value did you make that up or is it how it copies and pastes?
wombat
Wed Sep 20, 2017 5:21 pm
there is same as post in console..
idlemind
Wed Sep 20, 2017 5:32 pm
Ahh that must be how MikroTik expresses default and default-encryption. Just tested changing a value in each. I typically create my own profiles.
idlemind
Wed Sep 20, 2017 5:36 pm
I imagine you have a PPP secret, with it you can set routes that are set on the server side. In the PPP secret set the routes value like so (adjust the name in the find statement):
/ppp secret [ find where name=MyPPPSecret ] routes="10.75.17.0/24 10.75.4.180 1"
strods
Wed Sep 20, 2017 5:54 pm
Each tunnel (if you do not use static-bindings) is dynamic interface - it disappears after disconnect. After that all related configuration loses this parameter. You either need to specify route in PPP settings as mentioned before or use static binding:
https://wiki.mikrotik.com/wiki/Manual:I ... PTP_Server
Users browsing this forum: Google [Bot] and 56 guests
