YazzY
default-forwarding
Tue Jun 08, 2004 10:19 am
From http://www.mikrotik.com/docs/ros/2.8/in ... ess.simple
default-forwarding (yes | no; default: yes) - to use forwarding by default or not
What does that exactly mean ? Is it to enable/disable possibility for the clients to talk to one another or maybe it enables/disables only one to one communication for the customers?
YazzY
normis
Tue Jun 08, 2004 10:26 am
yes, if default forwarding is off, the wireless clients won't be able to communicate with eachother
YazzY
Tue Jun 08, 2004 10:30 am
What if you have two APs, one client connected to one of them and the other client connected to the other AP, both APs are on the same network.
Will they still be able to communicate with eachother even with default forwarding turned off ?
nhalachev
Tue Jun 08, 2004 11:58 am
Yes. they still be able to communicate with eachother even with default forwarding turned off.
Users browsing this forum: rngelmiguel and 118 guests
