gius64
Super strange issue with 0.0.0.0
Thu Sep 28, 2017 10:47 am
Hi everyone,
I’m having a strange issue on my router.
My WAN is completely saturated and I can’t have a good service. I can’t understand why: if I go on “Torch” I see all traffic to 0.0.0.0.
Could you help me to understand?
You can look at the screenshot attached for more details.
dadaniel
Re: Super strange issue with 0.0.0.0
Thu Sep 28, 2017 10:50 am
That's an old bug in Webfig that is still not fixed. Hit Stop button and Start button and it will show correct values.
gius64
Thu Sep 28, 2017 11:09 am
Thank you for your answer, unfortunately it didn’t solve my display issue.
Screenshot attached
strods
Thu Sep 28, 2017 11:26 am
Check other parameters on Torch and afterwards you should see what kind of traffic is this. For example, ARP requests.
gius64
Thu Sep 28, 2017 11:58 am
I checked all parameters but I can still see 0.0.0.0
strods
Thu Sep 28, 2017 1:33 pm
Torch shows all info if all fields are checked. For example, if you will disable "Protocol", then you will not see protocol information. In Webfig the very last line in results is a line with total traffic on the device. We will try to delete it or show in more understandable way.
Users browsing this forum: nichky, sphairos and 96 guests
